Re: [mpi3-coll] Neighborhood collectives round 2: reductions
On Sun, Dec 16, 2012 at 09:53:55PM -0800, Jed Brown wrote:
On Sat, Dec 15, 2012 at 8:08 AM, Torsten Hoefler <[1][email protected]> wrote:
> � �Those use cases ([3][2]http://lists.mpi-forum.org/mpi3-coll/2011/11/0239.php) > � �were all dependent on being able to reduce to overlapping targets. Depends on your definition of target. �If you mean processes by "targets", then the current interface proposal provides this; if you mean memory locations at one process by "targets", then this will not be possible within current MPI semantics.
I mean that the memory overlaps on the processor accumulating the result of the reduction. Think of a bunch of subdomains of a regular grid with one or two cells of overlap. An example of a "reduction" is to add up the contribution from all copies of each given cell. Cells near the middle of a "face" are only shared by two processes, but corner cells are shared by several processes. Yes, that would certainly work with the current proposal (not if we want to support MPI_IN_PLACE, but that wasn't planned anyway).
> � �As for defining "identity", the operation I would like is to reduce by > � �combining with a local buffer (usually in-place destination buffer). That > � �is, if I have the local buffer > � �mine = [1.1, 2.1, 3.1, 4.1, 5.1, 6.1] This can be expressed as a self-edge (we can discuss about in-place arguments, but then you would need to guarantee that the local buffer is larger than the largest neighbor buffer).
Useful application semantics would require the same.
Well, so it's no issue.
> � �and vector types for my two neighbors (defined by me) > � �incoming_type[0] = [0, 3, 4] > � �incoming_type[1] = [1, 4] > � �with incoming data (actually getting sent) > � �incoming_data[0] = [10.2, 20.2, 30.2] > � �incoming_data[1] = [100.3, 200.3] > � �the result would be > � �[op(1.1, 10.2), op(2.1, 100.3), 3.1, op(4.1, 20.2), op(5.1, 30.2, 200.3), > � �6.1] > � �This would be a natural expression of the operation I call "SFReduce" in > � �[4][3]http://59A2.org/files/StarForest.pdf I see, this may be doable with the vector interface (if we remove the restriction of equal vector sizes -- this would remove some optimization opportunities). Can you confirm that the current proposed neighbor_reducev() interface can cover this case?
If you remove the restriction of equal vector sizes, are you going to add an MPI_Datatype describing where to put the result? (I'd expect that to be a neighbor_reducew.) Note that in general, there would be some points shared by neighbors {1,2} and other points shared by neighbors {1,3} (and {2,3}, ...) thus we can't just sort such that the reduction is always applied to the "first N" elements.
Yes, I understand. We did not plan on a *w interface yet, however, it's straight-forward and I'd be in favor of it. The current *v interface would only support contiguous arrangements but I'll carry the request for th obviously useful w interface to the Forum.
One remaining question is if you can always guarantee "packed" data, i.e., that the "empty" elements are always at the tail. Well, I guess you could always add identity elements in the middle to create gaps.
I could pack, but I thought the point of the W interfaces was to enable the user to avoid packing (with possible performance advantages relative to fully-portable user code).
Yes, definitely! Unfortunately, DDTs are not always fast :-/.
Also, would the static communication topology work for your use-cases (neighborhoods don't change for a while).
Yes, comm topology is typically static, and we wouldn't use the neighborhood routines if it was changing frequently.
Excellent! Thanks, Torsten -- ### qreharg rug ebs fv crryF ------------- http://www.unixer.de/ ----- Torsten Hoefler | Assistant Professor Dept. of Computer Science | ETH Z�rich Universit�tsstrasse 6 | Zurich-8092, Switzerland CAB E 64.1 | Phone: +41 76 309 79 29
participants (1)
Torsten Hoefler
