Re: [mpi3-coll] Telecon to discuss DV-collectives (Alltoalldv)
On Thu, Oct 13, 2011 at 10:55:47AM -0700, Adam T. Moody wrote:
A couple more things... :-) -- more comments below!
In Santorini, Rich brought up a couple of concerns that should be considered. For one, he suggested that a slightly more general interface might be better in which you specify a base count for all processes, and then provide a list for processes that are different than that count. This could subsume the interface I listed below if you set the base count to be 0 and then list each non-zero item. The nice thing about the base count approach is that it nicely handles the "mostly regular" case, in which nearly all procs have the same amount of data but only a few have a little more or a little less. For example, this interface might look something like the following (added basecount and removed displacements which need some thought here):
MPI_Alltoalldv( sendbuf, sbasecount, nsends, sendranks[], sendcounts[], sendtype, /* O(sbasecount*P + k) list */ recvbuf, rbasecount, nrecvs, recvranks[], recvcounts[], rectype, /* O(rbasecount*P + k) list */ comm );
In the above, you would send/receive basecount data items from all procs, except for a few ranks, whose counts are listed explicitly in O(k) lists. Setting sbasecount/rbasecount=0 essentially reduces this interface to the one below (ignoring displacements). Yes, that may be interesting for the use-case I have in mind (a 3d FFT on a circular (cutoff) region), however, may be too limited for other use cases (which I don't know).
The other thing Rich was concerned about was whether an interface could be specified in such a way to reduce communication of the distributed count values. One extension that might help here is to allow the application to provide minimum and maximum count values that would apply globally across all processes. For example, with a maximum count value in gatherdv, you could set up a tree expecting the maxcount from all children but just receive less during each step. On the otherhand, if the min and max values are far apart, the implementation might fall back to something more dynamic so it doesn't allocate a bunch of temporary memory that it'll never use. If an application can't specify minimum or maximum values, it could always pass MPI_UNDEFINED for the min/max values. Yes, such tricks may simplify some implementation options. I'm not 100% sure how well they integrate with the current MPI syntax and semantics :-). But I guess recv is also only specifying a maximum. Keep in mind that this discussion may bring us then back to the displs[] array.
Thanks & Best, Torsten -- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ ----- Torsten Hoefler | Performance Modeling and Simulation Lead Blue Waters Directorate | University of Illinois (UIUC) 1205 W Clark Street | Urbana, IL, 61801 NCSA Building | +01 (217) 244-7736
participants (1)
Torsten Hoefler
