Re: [mpiwg-coll] backward communication in neighborhood collectives
Dan, Using your approach, I have to specify zero messages in arguments to MPI_NEIGHBOR_ALLTOALLV, because I only do communication in one direction in one time. Also, in my graph, there may have edges A->B and B->A. They may have different weights. Using your approach, it is quite confusing. One uses MPI_NEIGHBOR_ALLTOALLV to have better performance. We have to keep it in mind. --Junchao Zhang On Mon, Jul 23, 2018 at 9:59 AM, HOLMES Daniel <[email protected]> wrote:
Hi Junchao Zhang,
You are correct - the neighbourhood collectives send messages to (and receive messages from) only neighbouring MPI processes, as defined by the virtual topology. However, it is possible to use point-to-point, single-sided, or normal collective functions to send (and receive) messages between *any* MPI processes in a communicator, irrespective of the presence/structure of a virtual topology.
For your use-case (if I understand it correctly), you should specify a symmetric graph - each process specifies to MPI_DIST_GRAPH_CREATE_ADJACENT all the processes it wishes to communicate with (both sending and receiving) during subsequent calls to MPI_NEIGHBOR_ALLTOALLV.
Cheers, Dan. — Dr Daniel Holmes PhD Applications Consultant in HPC Research [email protected] Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 3415, JCMB, The King’s Buildings, Edinburgh, EH9 3FD — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. —
On 23 Jul 2018, at 15:45, Junchao Zhang <[email protected]> wrote:
Hello, Dan, I am interested in MPI_Neighbor_alltoallv. From its arguments, I do not see one can send a message to a neighbor not specified in the graph created by for example, MPI_Dist_graph_create_adjacent.
--Junchao Zhang
On Mon, Jul 23, 2018 at 5:51 AM, HOLMES Daniel <[email protected]> wrote:
Hi Junchao Zhang,
My understanding of the current API for MPI-3.1 is that:
1) the virtual topology does not actually restrict communication via the communicator to the edges specified in the topology - messages can be sent along any edge in either direction, and even between pairs of processes for which no edge was specified.
2) the virtual topology can be specified as a symmetric graph - for every ‘forward’ edge (e.g. from A to B), the ‘backward’ edge (i.e. from B to A) can be included as well.
3) there is already language in the MPI Standard regarding how MPI handles symmetric and non-symmetric graph topologies for neighbourhood collective operations.
Thus, there is no need to create two distributed graph topology communicators to achieve ‘forward and backward communication along the edges’.
On 15 Jul 2018, at 10:42, Anthony Skjellum <[email protected]> wrote:
Hi, I just saw this.
We definitely need to consider this concern.
I also need to go review the APIs.
Thanks, Tony
On Sat, Jul 14, 2018 at 12:27 AM, Junchao Zhang <[email protected]> wrote:
I want to try MPI neighborhood collectives. I have a communication graph and want to do both forward and backward communication along the edges. With current APIs, it looks I need to create two comm_dist_graphs. It is a waste since MPI implementations can do similar optimizations for the two. Should MPI support this scenario? Thanks.
--Junchao Zhang
_______________________________________________ mpiwg-coll mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-coll
-- Tony Skjellum, PhD RunTime Computing Solutions, LLC [email protected] direct: +1-205-918-7514 cell: +1-205-807-4968 _______________________________________________ mpiwg-coll mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpiwg-coll
participants (1)
Junchao Zhang
