Re: [mpi3-coll] Nonblocking collectives standard draft
At 01:39 PM 12/1/2008, Rajeev Thakur wrote:
MPI_Cancel cannot simply be ignored. For example, if there is an MPI_Isend followed by MPI_Cancel, and the matching receive is never called, the cancel cannot fail.
Are you sure that this is the way it works? It doesn't say so explicitly in the spec and the notes for MPI_Cancel on http://www-unix.mcs.anl.gov/mpi/www/ say "Cancel has only been implemented for receive requests; it is a no-op for send requests".
Those are some old web pages from somewhere :-). The standard says on pg 67 "If a send is marked for cancellation, then it must be the case that either the send completes normally, in which case the message sent was received at the destination process, or that the send is successfully canceled, in which case no part of the message was received at the destination. Then, any matching receive has to be satisfied by another send." So if a send is cancelled, and the destination program doesn't ever call a matching receive, the implementation has to cancel the send; it can't simply say the cancel failed. Otherwise, MPI_Cancel would be the easiest call to implement (along with MPI_Pcontrol) :-).
However, if we do need to provide the above semantics for MPI_Cancel, we will have to deal with a funny non-locality of behavior. Suppose we have an MPI_Ibcast and one of the receivers calls MPI_Cancel. What happens to the other participants? Do they all have to call MPI_Cancel to not participate or is any one calling it sufficient? What about things like MPI_Gather and MPI_AlltoAll? We certainly don't want to force non-all-to-all operations to have to do an all-reduce at the end to check for cancellation.
Yup, those are the issues that come up. One could say that MPI_Cancel is not allowed for nonblocking collectives. Rajeev
participants (1)
Rajeev Thakur
