Re: [mpi3-coll] Nonblocking collectives standard draft
Hi Torsten et al.,
the new version is in the wiki [1] and at [2]. Please check! Much better, thanks!
I did a second reading and found several but only minor issues with the text. If you send me the TeX sources, I can send you my proposed corrections/improvements directly as a patch file (diff). Some more things for discussion: - p. 49 l. 41: MPI has the concept of error handlers. I don't see a reason why we should forbid ("return an error code") its usage. My suggestion is to simply delete the two sentences (from "If the call ..." to "... cases."). - p. 61 l 33-38: Should we really keep this Advice for implementors (same result for MPI_IREDUCE when called with same arguments)? For the blocking variant, there stands this argument of reproducibility vs. performance. However, the non-blocking variant could be optimized much better (e.g., might handle bad process skew) and we should consider to weaken this semantic restriction to allow this better performance. - another argument _for_ MPI_REQUEST_FREE is the existence of intercommunicators where all processes (i.e., in group A and in group B) have to call the collective but only part of them might be involved (e.g., for MPI_IBCAST all but the root process in group A don't really participate in the operation - they pass MPI_PROC_NULL as root argument). So having a lightweight MPI_Wait alternative might not be too bad ... The NBC examples are quite buggy (missing MPI_STATUS in MPI_Recv, missing semicolons, duplicate usage of same req-argument -> bad Waitall, ...) - but as with the text, I can send you corrected versions in the diff. Best regards, Christian -- Christian Siebert, Dipl.-Inf. Research Associate NEC Laboratories Europe, NEC Europe Ltd. Rathausallee 10, D-53757 Sankt Augustin, Germany Phone: +49 (0) 2241 - 92 52 44 Fax: +49 (0) 2241 - 92 52 99 (Registered Office: 1 Victoria Road, London W3 6BL, 2832014)
participants (1)
Christian Siebert
