Re: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
Hi, Thanks. As soon as there's a couple of non-blocking recvs out there, waiting for them in reverse order requires tracking of the moment when the receives were posted. In some cases this leads to extra fields and data exchanges. The footprint argument generally says that the library will be smaller. This may be a minor matter for general purpose computers, but as soon as you go to Petascale, you need every byte on the compute nodes for user data, especially if dynamic libraries are not supported. As for the collectives, many are implemented using SendRecv, and that blocking call in turn often uses non-blocking communication. Classic Alltoallv algorithm uses nonblocking calls, too. So, I'm not sure that even unoptimized blocking collectives will always use only blocking pt2pt. Best regards. Alexander -----Original Message----- From: mpi3-subsetting-bounces_at_[hidden] [mailto:mpi3-subsetting-bounces_at_[hidden]] On Behalf Of Torsten Hoefler Sent: Friday, February 29, 2008 5:44 AM To: mpi3-subsetting_at_[hidden] Subject: Re: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09 Hi Alexander,
Thanks. What subsets inside the current standard would you propose? What interfaces between them would you envision? that is a long discussion, I guess. So just to put something up for discussion:
One subset could be collective communication and it would use Send/Recv from the MPI-core interface. Same for non-blockong colls (using nonblocking send/recv). Again, this is a logical design, it enables us to easily implement a portable library that only uses this interface and offers the standardized features. This library can be imported by vendors who do not want to optimize the substet that is supported by the lib. However, the MPI implementor is free to ignore the interface and do the collectives inside the library in a monolithic way (for performance). Other subsets could be: - topology functions - language bindings (certainly needs discussion) - data-type handling - groups/communicator handling (interface definition would be complex) - profiling interface (similar to language bindings) - parallel I/O - process management - one-sided (if this is not in core) - grequests
Good idea about the optimization opportunities. Here's an initial combined list, with the main benefits as I see them. Please comment/extend.
- Dynamic process support: less overhead in the progress engine, easier global rank handling. ack
- Heterogeneity: better memory footprint, easier data handling. easier equals faster in this case
- Derived datatypes (especially those with holes): better memory footprint. hmm, I don't get the memory footprint argument? But I'd say that it simplifies the critical path (one if less) and many applications just don't need datatypes. This is necessary if we want to broaden our scope (cf. the sockets interface has no datatypes and works well)
- MPI_ANY_SOURCE: faster, more simple multifabric progress. ack + receiver-based protocols (I wrote about this in "Optimizing non-blocking Collective Operations for InfiniBand" will be presented at the CAC workshop at IPDPS'07.
- File I/O: smaller requests, easier wait/test functions. yes
- One-sided ops: no passive target w/o MPI calls - no extra progress thread. - Communicator & group management: better memory footprint. - Message tagging: better support for stable dataflow exchanges, smaller packets. ack
- Non-blocking communication: easier ordering, simplified request handling. I am not sure about this since only the local matching differs (slightly) here, i.e., packets match a waiting recv (potentially dozens of them in different threads) vs. packets match a non-blocking request. This is pretty much the same overhead. How does that influence MPIs ordering constraints?
Best, Torsten -- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ ----- Indiana University | http://www.indiana.edu Open Systems Lab | http://osl.iu.edu/ 150 S. Woodlawn Ave. | Bloomington, IN, 474045-7104 | USA Lindley Hall Room 135 | +01 (812) 855-3608 _______________________________________________ Mpi3-subsetting mailing list Mpi3-subsetting_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-subsetting --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
