MPI3: Proposal to remove PMPI-Requirement
Dear Alexander, dear all, at the previous Chicago meeting, some of us (Rich Graham, Jeff Squyres, Hubert Ritzdorf) have been discussing about the MPI-Standard's requirement to provide PMPI-functions for each MPI-Call into the library (except MPI_Wtime, MPI_Wtick). This is in my eyes a limitation: there could be some gains for the common case of large-scale applications: - Not using PMPI-based tools (dynamically loaded in) - Not using MPI_PROC_NULL - Not using MPI_STATUS_IGNORE So, if this proposal would fit Your definition of MPI3-Subsets, I would like to discuss the removal of the PMPI-function requirement, allowing inlining of MPI-functions and, based on that, pre-processor hints, e.g. MPI_HINT_NO_THREADS or MPI_HINT_NO_ANY_SOURCE, so the compiler might be able to eliminate several if-statements in the fast-path, allowing inlining, allowing dead code elimination. (of course, there is a whole lot of further issues involved, here -- please see the last section in the document). I have included some timings with NetPipe on Open MPI using these hints (further information section 4 -- Ompi Patch availble upon request, as its work in progress). Please take the timings with a grain of salt. I would like to get better figures on a more well-defined cluster environment. Any comments would be welcome. With best regards, Rainer -- ---------------------------------------------------------------- Dipl.-Inf. Rainer Keller http://www.hlrs.de/people/keller HLRS Tel: ++49 (0)711-685 6 5858 Nobelstrasse 19 Fax: ++49 (0)711-685 6 5832 70550 Stuttgart email: keller_at_[hidden] Germany AIM/Skype:rusraink *
participants (1)
unknown@example.com
