Re: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
Alexander: It is the vast majority of scientific applications. It is not just ones that need sparse data structures. A stencil application that uses dense matrices has strided non-contiguous data transfers for half (2D) or more (3D or more complex stencils) of its communication. Non-contiguous communication is the reality of distributed memory computing... I am fine with letting this rest but my point is that an emphasis on performance by implementers should be the case for datatypes... Bronis On Fri, 29 Feb 2008, Supalov, Alexander wrote:
Dear Bronis,
Thanks. What scientific computing codes do you mean here - chemistry, structural mechanics, fluid dynamics, genomics, something else? Or do you speak generally of any code that needs sparse data structures? If so, what's your estimate of the relative number of such codes compared to those that do not need sparse datatypes? In what domain?
The right doze of vendor motivation not to do wrong things is a good point, I'll consider it.
Finally, the constant stride copying was but an example when inlining may help to users achieve higher performance. There may be other examples known in the scientific computing area. However, since performance is not primary goal for datatypes, I suggest we let this matter rest for a while.
Best regards.
Alexander
-----Original Message----- From: Bronis R. de Supinski [mailto:bronis_at_[hidden]] Sent: Friday, February 29, 2008 10:11 AM To: Supalov, Alexander Cc: mpi3-subsetting_at_[hidden] Subject: RE: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
Alexander:
Re:
Thanks. I understand your motivation. When you say "most real applications" - what applications do you mean? At least, in what area?
? Scientific computing...
For the NIC part, the stress was on "here". In my opinion, subsetting is not about making things more complicated, more challenging to the implementors, or to the underlying hardware. It's about making things simple, easy to use, and easy to implement - including implementation of only those features your users actually need. That the implementation may be faster due to this is an added bonus, not the primary goal.
The emphasis here should not be on creating a disincentive for vendors to do the right thing...
Still, regarding user side copying. Yes, when people do this one wonders why. There's a reason, apart from them: 1) not caring about datatypes and their complexity and 2) not trusting their performance. A modern compiler can rather well optimize a loop with a constant stride, and may have difficulty with an unknown stride. This is why explicit loops are sometimes indeed faster (much faster) in the resulting code than any generic implementation.
Huh? What makes you think the user copying code is in terms of constant stride? Generally, it varies with the input. We are not talking about a simple situation to optimize at the user level...
Bronis
Best regards.
Alexander
-----Original Message----- From: Bronis R. de Supinski [mailto:bronis_at_[hidden]] Sent: Friday, February 29, 2008 6:20 AM To: Supalov, Alexander Cc: mpi3-subsetting_at_[hidden] Subject: RE: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
Alexander:
Most real applications need to send non-contiguous data. If they do not use datatypes then they are doing the equivalent of either the packing/unpacking or smaller messages at the user level. This s hould be discouraged, not encouraged. A small savings in library object size is not ample reason to go against that. And, yes, we are after encouraging hardware vendors to provide the right hardware.
Bronis
Thanks. I think the main thrust here is the library footprint (no pack/unpack, etc.) and complexity of the user side of the datatype interface, rather than performance. Many applications just don't
need
any of this, and never will. Why not translating this application non-requirement into a minimum MPI subset? Same with communicator/group management, etc.
Moreover, homogeneous installations that dominate HPC now don't actually need any datatype support at all. They send chunks of bytes. This may change in the future, though.
A minor performance implication is that without holes that are only possible with derived datatypes, one does not need to track this, split the critical path, and make special provisions inside the MPI device layer to handle iov or such.
The NIC capability argument is interesting, but it turns the discussion on its head: we're not after motivating network vendors to provide scatter/gather in hardware here, are we? Please clarify.
Best regards.
Alexander
-----Original Message----- From: mpi3-subsetting-bounces_at_[hidden] [mailto:mpi3-subsetting-bounces_at_[hidden]] On Behalf Of Bronis R. de Supinski Sent: Friday, February 29, 2008 5:53 AM To: mpi3-subsetting_at_[hidden] Subject: Re: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
All:
OK, I have to respond to the notion that derived datatypes limit performance. It is just not a reasonable position.
Sure, if you can send contiguous locations, you will get higher performance. The problem is that codes do not only need to send contiguous data so that is not an adequate reason to say derived datatypes limit performance.
So, what is left? That there is some more efficient way to send non-contiguous data? How? As multiple messages, each of which send contiguous data? If so, then the implementation could do this under the covers and the datatypes are just a convenience for the user not to have to specify the individual sends. OK, suppose that's not the reason. Perhaps the user can do the copying into a contiguous buffer and get better performance? While I have seen this hold with some implementations, it is absurd. There is no reason that I can discern as to why the user should be able to deduce a better copying mechanism than the MPI implementer. So, again, at worst, the datatypes should be a convenience. Do you have an alternative reason or a refutation of these opinions?
What is more important, it is certainly possible to build scatter/gather support into a NIC and achieve better performance with datatypes than without. While there are issues to be resolved for that (primarily the issue of pinning memory), they are solvable with the right hardware mechanism. Just because it does not yet exist is not an adequate reason to say "Get rid of datatypes". OK, you are not saying that but you are saying to deprecate them in a sense. And saying you could send contiguous sends more efficiently is a bad argument here. How do datatypes cause inefficiency for that? How much is that cost really? At what point do you hit where the answer is "It would be faster not to compute anything"?
Bronis
Thanks. What subsets inside the current standard would you propose? What interfaces between them would you envision?
Good idea about the optimization opportunities. Here's an initial combined list, with the main benefits as I see them. Please comment/extend.
- Dynamic process support: less overhead in the progress engine, easier global rank handling. - Heterogeneity: better memory footprint, easier data handling. - Derived datatypes (especially those with holes): better memory footprint. - MPI_ANY_SOURCE: faster, more simple multifabric progress. - File I/O: smaller requests, easier wait/test functions. - One-sided ops: no passive target w/o MPI calls - no extra progress thread. - Communicator & group management: better memory footprint. - Message tagging: better support for stable dataflow exchanges, smaller packets. - Non-blocking communication: easier ordering, simplified request handling.
Best regards.
Alexander
-----Original Message----- From: mpi3-subsetting-bounces_at_[hidden] [mailto:mpi3-subsetting-bounces_at_[hidden]] On Behalf Of Torsten Hoefler Sent: Friday, February 29, 2008 5:08 AM To: mpi3-subsetting_at_[hidden] Subject: Re: [Mpi3-subsetting] agenda for subsetting kickoff telecon ww09
Present: Leonid Meyerguz (Microsoft), Rich Graham (ORNL), Richard Barrett (ORNL), Torsten Hoefler (ISU), Alexander Supalov (Intel) just for the record, it's "IU" not "ISU" :-)
- Scope of the effort - Rich - Minimum subset consistent with the rest of MPI, for performance/memory footprint optimization - Danger of splitting MPI, hence against optional features in the standard I back that (danger of optional features for portability). I'd propose to split the current standard into mostly self-contained subsets that have clearly defined interfaces to the rest of the standard. Note: this only defines logical interfaces, that does *not* define how those things are to be implemented. This makes it easier to understand the standard and have separate (portable) libraries for the subsets, it does not influence optimization possibilities by implementing everything in a monolithic block (i.e., central progress).
- Both blocking & nonblocking belong to the core - Torsten - Some collectives may go into selectable subsets
I see three subsets: blocking colls, non-blocking colls and topological colls (maybe also blocking / non-blocking).
- MPI_ANY_SOURCE considered harmful
I'd like to add datatypes and heterogeneity to this list (with regards to performance). Alexander mentioned the dynamics. I think we should have a lit of items ready that could influence optimization possibilities significanty if they were to be announced by the user before he can use them. That would give another strong argument for the subsetting.
Best, Torsten
-- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/
Indiana University | http://www.indiana.edu Open Systems Lab | http://osl.iu.edu/ 150 S. Woodlawn Ave. | Bloomington, IN, 474045-7104 | USA Lindley Hall Room 135 | +01 (812) 855-3608 _______________________________________________ Mpi3-subsetting mailing list Mpi3-subsetting_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-subsetting
Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
--------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
participants (1)
unknown@example.com
