Re: [Mpi3-bwcompat] MPI Backward Compatibility Working Group
If we all like the text, sure - I'll make the latex changes. Sent from my phone. No type good. On Mar 13, 2011, at 2:22 PM, "Fab Tillier" <ftillier_at_[hidden]> wrote:
Jeff, I like your wording, looks good to me. Are you going to fix up the latex and generate new PDFs that we can send out?
-Fab
-----Original Message----- From: mpi3-bwcompat-bounces_at_[hidden] [mailto:mpi3-bwcompat-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Sunday, March 13, 2011 7:21 AM To: MPI-3 backwards compatability WG Subject: Re: [Mpi3-bwcompat] MPI Backward Compatibility Working Group
On Mar 11, 2011, at 6:06 PM, Solt, David George wrote:
2.5.8 Last sentence change to:
The size of the MPI_Count type is determined by the MPI implementation with the restriction that it must be minimally capable of encoding a C int and Fortran INTEGER and any value that may be stored in an MPI_Aint type.
"...and any value that may be stored in a variable of type MPI_Aint."
Rational thingy:
Rationale. Potatoes. :-)
MPI_Count is used to communicate both the number of elements in a datatype and the bounds of a datatype. The number of elements in a datatype is specified at creation time using a C int or Fortran INTEGER. The bounds may be specified using an MPI_Aint.
This is good. I would change the wording slightly -- let's not use the verb "communicate" here:
"MPI_Count explicitly specifies the number of elements in a datatype, and therefore implicitly specifies the bounds of that datatype. The number of elements in a datatype is specified at creation time using a C int or Fortran INTEGER. The extent of a datatype is expressed using an MPI_Aint.
How's that?
-- Jeff Squyres jsquyres_at_[hidden] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ Mpi3-bwcompat mailing list Mpi3-bwcompat_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-bwcompat
participants (1)
unknown@example.com
