Re: [Mpi3-bwcompat] MPI Backward Compatibility Working Group
What was the motivation for the new MPI_Type_get_extent_x and MPI_Type_get_true_extent_x functions? If we say MPI_Count should be at least as large as MPI_Aint, why can't we just use MPI_Aint instead? The data buffer can't be larger than Aint size. I know that for I/O MPI_Offset can be larger than Aint, but this proposal does not solve the I/O problem as far as I know. https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/265 Rajeev On Mar 11, 2011, at 5:06 PM, Solt, David George wrote:
During our meeting today we decided that MPI_Count should be at least as large as an MPI_Aint. We already had the restriction that it had to be as large as a C/Fortran integer. We want both restrictions (they cannot be combined because there is no guarantee that MPI_Aint > integer).
Ill throw this out as a starting point for discussion:
2.5.8 Last sentence change to:
The size of the MPI_Count type is determined by the MPI implementation with the restriction that it must be minimally capable of encoding a C int and Fortran INTEGER and any value that may be stored in an MPI_Aint type.
Rational thingy:
MPI_Count is used to communicate both the number of elements in a datatype and the bounds of a datatype. The number of elements in a datatype is specified at creation time using a C int or Fortran INTEGER. The bounds may be specified using an MPI_Aint.
So, I was especially brief here. I did not want to get into the new routines vs. old routines, but if you attempt to go into more depth than what I said, you will inevitably end up going down that path. I can think of a thousand ways not to say it, but its hard to come up with a good way. Dave
_______________________________________________ Mpi3-bwcompat mailing list Mpi3-bwcompat_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-bwcompat
participants (1)
unknown@example.com
