Re: [Mpi3-abi] For the April MPI Forum Meeting
Hi, I've updated Jeff's file in the Wiki: some formatting, some typos fixed (in red), etc. Best regards. Alexander -----Original Message----- From: Supalov, Alexander Sent: Friday, April 25, 2008 8:12 PM To: 'MPI 3.0 ABI working group' Subject: RE: [Mpi3-abi] For the April MPI Forum Meeting Hi, The initial ABI proposal draft (see http://svn.mpi-forum.org/trac/mpi-forum-web/attachment/wiki/AbiWikiPage/MPI%...) cites Bill Gropp's paper to introduce the MPI constant hierarchy basing on when the items are/should be defined according to the standard. We can use that hierarchy to split all ABI entities into groups. Here is the pertinent excerpt: - Compatible MPI data entities o Compile-time values § Used in declarations (MPI_MAX_ERROR_STRING, etc.) § Other (MPI_ANY_SOURCE, MPI_ERR_TRUNCATE, etc.) o Init-time constants (MPI_INT, etc.) o Opaque objects (MPI_Comm, MPI_Datatype, etc.) o Defined objects (MPI_Status) o Defined pointers (MPI_BOTTOM, MPI_STATUS_NULL, etc.) And while we're so focused on the mpi.h contents, I can't help reiterating that this is but a part of the ABI matter. The following is no less important for the whole thing to work: - Uniform approach to the macro implementation of certain functions (MPI_Wtime, MPI_Wtick, handle conversion calls, possibly others) - Similar calling convention o Argument order and size o Stack frame management policy o Return address storage and handling o Function call and return handling - Common linkage convention o Library file format o MPI library name o MPI library path resolution mechanism o System library dependency resolution Best regards. Alexander -----Original Message----- From: mpi3-abi-bounces_at_[hidden] [mailto:mpi3-abi-bounces_at_[hidden]] On Behalf Of Erez Haba Sent: Friday, April 25, 2008 6:01 PM To: MPI 3.0 ABI working group Subject: Re: [Mpi3-abi] For the April MPI Forum Meeting I think that we need enough data to put the constants into classes of constants that are different from one implementation to the other (examples for a classes, are "handles", "datatype"). Once done, we'll be able to understand the differences in the different implementations (approach) and in the different platforms. This will enable us to come up with reasonable suggestion for the ABI constants. I think that putting the constants in different spreadsheet (split by os/cpu) is reasonable. Thanks, .Erez -----Original Message----- From: mpi3-abi-bounces_at_[hidden] [mailto:mpi3-abi-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Friday, April 25, 2008 7:04 AM To: MPI 3.0 ABI working group Subject: Re: [Mpi3-abi] For the April MPI Forum Meeting On Apr 25, 2008, at 8:32 AM, Supalov, Alexander wrote:
The purpose of having as much input data as possible before deciding whether and how to proceed is to not miss a potentially important data point.
In this vein, I'd love to see some MPICH1 and HP MPI data there. That, with the data already in the spreadsheet, would most likely cover 99% of the currently targeted platforms (IA32/Intel64/Linux/Windows).
I'm all for having enough data points. I was questioning how many we need -- it just looked like we we diverging into the "need dozens of datapoints" realm. If we're not, no problem.
A split into several files would make sense if we had dozens of actively contributing members. At the moment we are blessed with but a few.
The wiki has no "lock" feature. SVN does, but we don't really have a common SVN. This is the canonical problem with binary formats -- more power in the binary-based tool (excel), but less collaboration ability. I suppose a sharepoint server would work...? But [I'm assuming] that would be a nightmare of licensing and access control setup. We could use a tex-based format (latex?) that allows merge capabilities, or use the wiki text format (but wikis don't handle simultaneous editing nicely -- someone inevitably "loses", rather than having the ability to merge their new text in). Splitting into mutliple files, each with a discrete author, might still be the best solution. [shrug] -- Jeff Squyres Cisco Systems _______________________________________________ mpi3-abi mailing list mpi3-abi_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-abi _______________________________________________ mpi3-abi mailing list mpi3-abi_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi3-abi --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
