George, Thanks! The change is committed in r1502. Torsten On Thu, Jul 19, 2012 at 10:25:08PM +0200, George Bosilca wrote:
Torsten,
When the usage of the MPI_LB and MPI_UB has been replaced by the resize function the arrays used by the MPI_Type_struct (displacement and blacken) have been left behind. The patch below clean one of the examples from the collective chapter.
george.
Index: chap-coll/coll.tex =================================================================== --- chap-coll/coll.tex (revision 1482) +++ chap-coll/coll.tex (working copy) @@ -1212,14 +1211,15 @@ %%HEADER %%LANG: C %%FRAGMENT +%%SUBST:...: %%SKIPELIPSIS %%ENDHEADER \begin{Verbatim}[commandchars=\\\$\^] MPI_Comm comm; - int gsize,sendarray[100][150],*sptr; - int root, *rbuf, stride, myrank, disp[2], blocklen[2]; - MPI_Datatype stype,type[2]; - int *displs,i,*rcounts; + int gsize, sendarray[100][150], *sptr; + int root, *rbuf, stride, myrank; + MPI_Datatype stype; + int *displs, i, *rcounts;
On Jul 19, 2012, at 20:21 , William Gropp wrote:
Yes, these need to be fixed.
Mixed case in the function index means either the C binding name (or Fortran08 name) was used where the language-independent name should be used, or \func or \mpifunc were used for a language-binding-specific name (which is incorrect macro usage). Chapter authors need to fix this. There as also some non-functions in the function index; those must be fixed.
Example index entries need to be checked; I added a bunch to context as many examples were missing the index entries (made with \exindex).
I think it is ok for removed and deprecated names to show up in the index.
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
On Jul 19, 2012, at 12:17 PM, Mohamad Chaarawi wrote:
Hi All,
After reviewing the indices, I found a few issues:
- MPI_Type_struct and MPI_TYPE_EXTENT show up in the example indices. This should not happen as they are removed. - I'm not sure if removed and deprecated routines should show up in the Function Index, but right now, they do. - similarly in the MPI Callback Function Prototype Index - similarly in Constant and Predefined Handle Index - in the function index, many routines show up twice (caps and no caps) and some show up only with no caps.. All should be caps (I think).
Do the chapter authors need to fix those in their chapters?
Thanks, Mohamad _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- ### qreharg rug ebs fv crryF ------------- http://www.unixer.de/ ----- Torsten Hoefler | Performance Modeling and Simulation Lead Blue Waters Directorate | University of Illinois (UIUC) 1205 W Clark Street | Urbana, IL, 61801 NCSA Building | +01 (217) 244-7736
participants (1)
Torsten Hoefler
