Re: [Mpi-forum] cancel in standard
One of the main reasons cancel send was introduced was for symmetry, since there were cancel receives too. But that argument has gone out the window with NBC, RMA and I/O requests which are all not cancelable. For everyone's information, we are working on three tickets. 1. An MPI-3.1 errata ticket to clarify the wording in the MPI standard as to what cancel send must do. This will also remove some incorrect wording in the standard with respect to the behavior of wait/test after a failed cancelation. 2. An MPI-3.2 ticket to deprecate send cancel citing all the complexities in implementing it efficiently. More importantly the cost of supporting send cancel on non-cancel operations. 3. An MPI-4.0 ticket to remove send cancel. -- Pavan Sent from my iPhone
On Jun 5, 2015, at 3:16 AM, Supalov, Alexander <[email protected]> wrote:
Just a note: MPI_Cancel would be next to MPI_ANY SOURCE to go had one introduced assertions. :)
-----Original Message----- From: mpi-forum [mailto:[email protected]] On Behalf Of William Gropp Sent: Thursday, June 4, 2015 2:24 PM To: Main MPI Forum mailing list Subject: Re: [Mpi-forum] cancel in standard
But the user did care about it, and they decided to cancel it. It may not be one message, but one per iteration. And the semantics is clear (even if the standard's language isn't).
Bill
On Jun 3, 2015, at 10:08 PM, Jeff Hammond <[email protected]> wrote:
What's the harm in letting a message that the user clearly does not care about sit in a queue/buffer forever? I consider this an acceptable consequence of a really stupid feature.
Jeff
On Wed, Jun 3, 2015 at 9:50 PM, William Gropp <[email protected]> wrote: Pavan is correct about the intent, and we could make this more precise. The basic requirement is that a message is *guaranteed* to either be canceled (on send) or received. Sitting in a queue or buffer somewhere does not count.
Bill
On Jun 3, 2015, at 7:19 PM, Balaji, Pavan <[email protected]> wrote:
[Cc'ed the Forum]
This wording has been debated many times at the Forum. Specifically, the "completes normally" and "received at the destination" pieces are ambiguous. For instance, if the data is copied into a bounce buffer, the send would complete normally, but that does not mean that there is a receive posted for that data. In this case, it would be the user's responsibility to post a corresponding receive. If the MPI implementation does not have a bounce buffer (e.g., for large messages), "received at the destination" could mean into an unexpected buffer, not necessarily a user buffer.
The consensus from MPI-1 veterans (Marc, Bill, etc.) during the last discussion was that if the application does not post a receive, then it is guaranteed that the send should be cancelable. At least that was the intent. The wording, of course, is too vague for such a definition.
You could try to weaken that interpretation and say that if the MPI implementation is not able to cancel a send operation, then the user is responsible for posting a matching receive to receive that data. Irrespective of which interpretation we go with, I think it is important to clarify it in the standard. Perhaps an MPI-3.1 errata or MPI-3.2 change instead of waiting for MPI-4? Do you want to create a ticket?
-- Pavan
On 6/3/15, 7:05 PM, "Sur, Sayantan" <[email protected]> wrote:
What lines in the standard support the interpretation that "a message that will not be successfully matched, must be cancelable"?
This is what I found, and it doesn't support the stricter interpretation.
"If a send is marked for cancellation, then it must be the case that either the send completes normally, in which case the message sent was received at the destination process, or that the send is successfully cancelled, in which case no part of the message was received at the destination. Then, any matching receive has to be satisfied by another send."
mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen, Deutschland Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Christian Lamprechter, Hannes Schwaderer, Douglas Lusk Registergericht: Muenchen HRB 47456 Ust.-IdNr./VAT Registration No.: DE129385895 Citibank Frankfurt a.M. (BLZ 502 109 00) 600119052
participants (1)
Balaji, Pavan
