Hi all, We'll have no virtual MPI Forum meeting today - so far, no forum wide discussions are ready from the side of the WGs and there wasn't much progress in direction of MPI 4.1, yet. For the latter, please take a look at the project board and see if you have an issue assigned to you and/or if there is something in a WG you are part of that should be pushed forward. Here is a link to the board: https://github.com/mpi-forum/mpi-issues/projects/3 In particular, it would be great of all Chapter Committee leads could look at the issues labeled "All CCs Must Check" https://github.com/mpi-forum/mpi-issues/projects/3?card_filter_query=label%3... and see if the changes for the respective chapter is still missing for that issue. Thanks! Martin -- Prof. Dr. Martin Schulz, Chair of Computer Architecture and Parallel Systems Department of Informatics, TU-Munich, Boltzmannstraße 3, D-85748 Garching Member of the Board of Directors at the Leibniz Supercomputing Centre (LRZ) Email: [email protected]
participants (1)
Martin Schulz
