Re: [Mpi-forum] Progress Question
In the scenario described by Jim, where a send must be reposted due to transient network failures, where the retransmission is handled in software, and where MPI provides no progress outside MPI calls, it seems plausible that an unexpected outcome will be reached (also assuming no timeouts or other corrective measures are taken by the network or software stack). - Rajeev’s example will eventually complete, because when the process impacted by the network issue will reach MPI_Finalize, the pending internal communications will be reissued and all processes will complete the MPI_Barrier. - In Jim’s original example it looks more likely that a deadlock will occur as there is no ensuing MPI call to reissue the message to be retransmitted, and a deadlock will occur. I don’t think we need transient network errors for such outcomes, it is enough to use a buffered send without followup MPI calls to reach the same delayed execution scenario. George. On Sun, Oct 11, 2020 at 14:28 Skjellum, Anthony via mpi-forum < [email protected]> wrote:
Rajeev, No, I don't think so. Did you all disagree with my reasoning? Tony
Anthony Skjellum, PhD
Professor of Computer Science and Chair of Excellence
Director, SimCenter
University of Tennessee at Chattanooga (UTC)
[email protected] [or [email protected]]
cell: 205-807-4968
------------------------------ *From:* mpi-forum <[email protected]> on behalf of Thakur, Rajeev via mpi-forum <[email protected]> *Sent:* Sunday, October 11, 2020 2:23 PM *To:* Jim Dinan <[email protected]> *Cc:* Thakur, Rajeev <[email protected]>; Main MPI Forum mailing list < [email protected]>
*Subject:* Re: [Mpi-forum] Progress Question
Does it mean that in the following program, although all processes have called barrier, some process may not exit the barrier for 100 days?
MPI_Init
MPI_Barrier
sleep(100 days)
MPI_Finalize
Rajeev
*From: *Jim Dinan <[email protected]> *Date: *Sunday, October 11, 2020 at 10:31 AM *To: *"Thakur, Rajeev" <[email protected]> *Cc: *Main MPI Forum mailing list <[email protected]> *Subject: *Re: [Mpi-forum] Progress Question
Hi Rajeev,
Yes, that's the question and my initial answer was the same as yours. However, we then started talking about the implementation of the barrier, which led to the second example. For example, consider a situation where there is an error in transmission and the implementation needs to enter the progress engine to retry a send operation in software.
~Jim.
On Sat, Oct 10, 2020 at 5:10 PM Thakur, Rajeev <[email protected]> wrote:
Jim,
I don’t fully understand your question. Is it “If all processes reach MPI_Barrier, are they guaranteed to exit the barrier without the need for any other MPI function to be called on any process?” I would say yes.
Rajeev
*From: *mpi-forum <[email protected]> on behalf of Jim Dinan via mpi-forum <[email protected]> *Reply-To: *Main MPI Forum mailing list <[email protected]> *Date: *Saturday, October 10, 2020 at 12:31 PM *To: *Main MPI Forum mailing list <[email protected]> *Cc: *Jim Dinan <[email protected]> *Subject: *[Mpi-forum] Progress Question
Hi All,
A colleague recently asked a question that I wasn't able to answer definitively. Is the following code guaranteed to make progress?
MPI_Barrier();
if rank == 1
create_file("test")
if rank == 0
while not_exists("test")
sleep(1);
That is, can rank 1 require rank 0 to make MPI calls after its return from the barrier, in order for rank 1 to complete the barrier? If the code were written as follows:
isend(..., other_rank, &req[0])
irecv(..., other_rank, &req[1])
waitall(2, req)
if rank == 1
create_file("test")
if rank == 0
sleep(1);
I think it would clearly not guarantee progress since the send data can be buffered. Is the same true for barrier?
Cheers,
~Jim.
_______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
George Bosilca
