Re: [Mpi-forum] Voting results
All: I also meant to address another question that arose. While I have missed some meetings, at no meeting at which I was present to a ticket pass under the apparent widespread misinterpretation of the rules. If one had, I would have objected -- first, because that is not what the by-laws say; and second, because adding something to the standard that cannot even get a simple majority of yes votes of THOSE PRESENT is an inherently stupid idea (adding it; not necessarily the proposal itself). I do not recall a particularly close vote when I was present although I might be mistaken. The only votes that I recall that were close were straw votes, which do not count. Many of those have been close. Bronis On Wed, 30 May 2012, Bronis R. de Supinski wrote:
All:
Hmm. Quite the controversy. However, the rules as enforced in Japan are consistent with my understanding of what they have always been. More importantly, they are consistent with the wording in the bylaws. Here is what Jeff quoted:
a simple majority is defined as a simple majority of those present and eligible to vote.
Those who abstained were present and eligible to vote. They did not vote yes. The effect is that they voted "no" by this definition. If they did not want their vote effectively to be "no" then they should have left the room. I recall several instances in which someone was out of the room (perhaps even momentarily for a bio break) and Jeff recorded their vote as "not present". See the definition above -- they then do not count as present so they do not figure into the required "yes" count.
As I stated, my understanding of the rules is consistent with the interpretation used in Japan. I would object to any other interpretation since the by-laws are actually clear on this point. I agree that the by-laws should be clear in general; while I think they are clear, I would not object to a clarifying statement being added to the effect that "abstentions are effectively negative votes." I think we have many other issues that should be made concrete in the by-laws and this is the least important. What is required to pass a first reading is probably the most obvious issue.
Bronis
On Wed, 30 May 2012, Fab Tillier wrote:
Jeff Squyres wrote on Wed, 30 May 2012 at 12:12:26
On May 30, 2012, at 2:57 PM, Jeff Hammond wrote:
The fact that some votes were still recorded as 'abstain' is an indication that this bylaw change was half baked.
Especially when the meeting is attended by so few people due to the location. It seems like a weasel tactic to pick a remote location to change the by-laws with a single vote.
To be clear, the process document states:
For the purposes of voting, a simple majority is defined as a simple majority of those present and eligible to vote. In the context of the document, the phrase "simple majority" is used to describe what is needed for ballots to pass; this sentence is attempting to define that phrase. So even though the above sentence looks like a circular definition, I think it's really an open-ended definition (e.g., a google search for "simple majority definition" turns up both definitions).
I was not there and don't know *exactly* what happened, so I'll refrain from commenting further.
If the bylaws are vague, we should clarify them. We should not however reinterpret them at each meeting, and should all agree on a proper interpretation and stick to it, such that ambiguity is removed going forward. Allowing our bylaws to be vague enough to afford a re-interpretation at each meeting does nobody any good.
-Fab
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
