Re: [Mpi-forum] "BigCount" rendering in PDF
Hi Jeff, To be clear, C++ currently calls/uses the C99 interface for MPI (unless it uses the no-long-standard but possibly-still-present-in-libraries C++ bindings). That will still be true after these BigCount changes: C++ will see only the C99 symbols, just like any other non-C11-compliant compiler. Polymorphism will not be supported in C++ because it cannot use C11 _Generic (because that is part of the C11 standard and is *not* part of the C++ standard). It also cannot use C++ overloading because are choosing not to define any new C++ bindings in the MPI-4.0 standard. If libraries choose to supply C++ overloads, they may do so but they are not going to be part of the MPI-4.0 standard (they will have the same status as the Java bindings offered by Open MPI). Cheers, Dan. — Dr Daniel Holmes PhD Architect (HPC Research) [email protected]<mailto:[email protected]> Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 2.09, Bayes Centre, 47 Potterrow, Central Area, Edinburgh, EH8 9BT — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. — On 31 Jul 2019, at 16:03, Jeff Squyres (jsquyres) via mpi-forum <[email protected]<mailto:[email protected]>> wrote: On Jul 31, 2019, at 10:52 AM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: You’re going to have to mention C++. You can’t just pretend that C++ supports C11 generic, because it explicitly doesn’t. We are mentioning C++. Please re-read my prior email. And you really should do this because it’s ridiculous not to use C++ polymorphism if we use C11’s. There are three options: 1. Re-introduce C++ bindings, delay MPI-4. 2. Re-introduce C++ bindings, BigCount misses the MPI-4 train. 4. Do not re-introduce C++ bindings, BigCount catches the MPI-4 train. The feedback from the Forum was that BigCount was a blocker/gating issue for MPI-4. Hence, this is why the BigCount WG is not planning at this time to re-introduce C++ bindings via BigCount. There is a longer term plan (think: MPI-5) to introduce a full-featured set of C++ bindings to MPI -- one that does not necessarily have a 1:1 correspondence to the C bindings. That is a different, much longer effort, and will definitely not make it into MPI-4. -- Jeff Squyres [email protected]<mailto:[email protected]> _______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
HOLMES Daniel
