Re: [Mpi-forum] Fortran Ticket #229
Dear all chapter-authors, I checked in the correct mpi-report.tex and ADD-F2008.sed as svn release 1193. Jeff tested it already and it works. Thank you, Jeff and Darius. My apologies about this copy-error. I worked on a local directory and use the approved/MPI-3.0 trunk only for the check-in. Now, all seems to be correct. The pdf file on ticket #229 is still correct, because I did not modify the sources. Best regards Rolf ----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Wednesday, June 27, 2012 6:05:42 PM Subject: Re: [Mpi-forum] Fortran Ticket #229 Now, I know the bug, and come back in a few minutes with the correction.
My apologies.
Rolf
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Wednesday, June 27, 2012 5:52:01 PM Subject: Re: [Mpi-forum] Fortran Ticket #229 Darius,
it may by that the "sed" or the "sh" is not as standardized as expected.
I have a second (the old) version of MAKE_FUNC_INDEX that may run in some linux systems.
I do not uderstand where which version is needed.
Old MAKE_FUNC_INDEX is attached.
Please check and tell me the result.
Best regards Rolf
From: "Darius Buntinas" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Wednesday, June 27, 2012 5:12:30 PM Subject: Re: [Mpi-forum] Fortran Ticket #229 The approved branch fails to build. It looks like maybe mpireport.tex was corrupted in the r1191 ?
-d
On Jun 27, 2012, at 9:05 AM, Richard Graham wrote:
Rolf/All, The approved branch is only for chapter authors to write to - this is where we take the draft-standard drops. Since the change is large, it does not make sense to back out these changes, and have the chapter committees put them in after going over them and verifying the. Instead, if each chapter committed could let me know that they have looked over the changes, and are OK with them, that will be best. I would like to put out a draft-standard by early next week with all the changes that people have made, so the folks can start to look over it before the next meeting. PLEASE let me know when you have looked over the changes.
Thanks, Rich
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Rolf Rabenseifner Sent: Wednesday, June 27, 2012 8:40 AM To: Main MPI Forum mailing list Subject: Re: [Mpi-forum] Fortran Ticket #229
the merge of existing approved/MPI-3.0/* (svn release 1189) and the whole Fortran ticket #229 is completed and checked in as (1190,) 1191, (and 1192).
Please "svn update" you whole approved/MPI-3.0/ to receive all the changed files.
With this "my write-lock" on the whole source is released now.
Best regards Rolf
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Monday, June 25, 2012 4:04:47 PM Subject: Re: [Mpi-forum] Fortran Ticket #229
I hope, that all chapter authors do not edit the tex files today and tomorrow. Otherwise they can do it again. or merge the hughes Fortran changes into their changes.
I'll come back with the results tomorrow.
Rolf
From: "Jeff Squyres" <[email protected]> To: "Main MPI Forum mailing list" Sent: Monday, June 25, 2012 3:59:32 PM Subject: Re: [Mpi-forum] Fortran Ticket #229
Thanks Rolf!
all chapters are touched by the new Fortran interface #229.
I just started to include all ticket #229 into all .tex files based on current svn/mpi-forum-docs/approved/MPI-3.0/ SNV release 1189
I'll try to give you the modified .tex for your chapter. Of course, I'll not update this in the SVN because you only are allowed to commit (check in) new tex files.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
Rolf Rabenseifner
