Re: [Mpi-forum] Semantic Terms (Issue #96) Reading Announcement
Annotated PDF files are now available under Issue #96, here are the direct links: Version-1: https://github.com/mpi-forum/mpi-issues/files/4780761/mpi40-report-520db9c-j... Version-2: https://github.com/mpi-forum/mpi-issues/files/4780771/mpi40-report-f51be45-j... Thanks, Puri ________________________________ From: mpi-forum <[email protected]> on behalf of Bangalore, Purushotham via mpi-forum <[email protected]> Sent: Monday, June 15, 2020 8:15 AM To: Wesley Bland via mpi-forum <[email protected]> Cc: Bangalore, Purushotham <[email protected]> Subject: [Mpi-forum] Semantic Terms (Issue #96) Reading Announcement Here is the official announcement for reading issue #96 related to Semantic Terms: Issue #: https://github.com/mpi-forum/mpi-issues/issues/96 PR: https://github.com/mpi-forum/mpi-standard/pull/116 There are two versions currently provided for reading, based on the feedback from the Forum we will only read one version, the PDF file for the two versions can be found here: Version-1: https://github.com/mpi-forum/mpi-standard/files/4779984/mpi40-report-520db9c... Version-2: https://github.com/mpi-forum/mpi-standard/files/4779988/mpi40-report-f51be45... The difference between the two versions is in the locality of MPI_RSEND and MPI_MRECV functions (that can be found here<https://github.com/mpi-forum/mpi-standard/pull/116/files/520db9c157951605f3640718cc9ef96d3ee5bf0c..f51be453bd3ca2f8100a067145aa9d6a49dc8f4f>) and corresponding entries in the table in Appendix A.2 (page 723) in the PDF files above. Annotated PDF files will be available soon under this issue on github. Thanks, Puri (on behalf of the WG)
participants (1)
