Can someone take a look at the second example in: http://www.mpi-forum.org/docs/mpi-20-html/node124.htm and also to the example in: http://www.mpi-forum.org/docs/mpi-20-html/node125.htm I believe in both cases the lines saying j = map(i)/p k = MOD(map(i),p) should read j = map(i)/m k = MOD(map(i),m) Additionally, in the first example again in: http://www.mpi-forum.org/docs/mpi-20-html/node124.htm in the part where origin and target indices are computed, there are two lines reading: oindex(total(j) + count(j)) = i tindex(total(j) + count(j)) = k Should'nt it read like this (for indices being zero-based)? oindex(total(j) + count(j)) = i - 1 tindex(total(j) + count(j)) = k - 1 Regards, -- Lisandro Dalc�n --------------- Centro Internacional de M�todos Computacionales en Ingenier�a (CIMEC) Instituto de Desarrollo Tecnol�gico para la Industria Qu�mica (INTEC) Consejo Nacional de Investigaciones Cient�ficas y T�cnicas (CONICET) PTLC - G�emes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Lisandro Dalcin
