Re: [Mpi-forum] [EXTERNAL] Wording in MPI standard
There's a lot of ambiguity in the definitions of these words in different contexts. If the MPI Forum wants "should" to mean "is required to", then such a definition should be explicit in the text.
From http://en.wikipedia.org/wiki/Shall_and_will#Technical_specifications:
"The IETF (Internet Engineering Task Force) defines shall and must as synonymous terms denoting absolute requirements, and should as denoting a somewhat flexible requirement, in RFC documents." Jeff On Tue, Nov 27, 2012 at 9:48 AM, Rajeev Thakur <[email protected]> wrote:
If you search for the word "should" in the document, it is used all over the place. And it does not mean "maybe" http://dictionary.reference.com/browse/should?s=t
Rajeev
On Nov 27, 2012, at 8:23 AM, Pavan Balaji wrote:
On 11/27/2012 04:48 AM US Central Time, Jeff Hammond wrote:
Is it explicitly defined anywhere that "foo has been started" means "MPI_I*foo has been called by the appropriate MPI rank" or "sufficient matching has occurred such that foo can proceed without additional explicit remote activity"? Perhaps this text would be more clear if it were more pedantic in this respect, assuming either of my equivalences are correct.
I think this needs to be clarified -- I always tell people that it needs to be matched (even though the standard says it should have "started" -- what does that mean, if matching has started, but not completed, is it considered "started").
As for language, while "should" isn't legally enforceable in the same way that "must" or "shall" are, the MPI standard is not a legally binding document and I don't think any MPI implementer wants to be known as the jerk that exploits this loophole to create a formally standard-compliant implementation that screws over users by violating the principle of least surprise in important use cases such as Scott's example.
I have to agree with Scott here -- "must" or "is required to be" is a clearer way to describe it.
-- Pavan
-- Pavan Balaji http://www.mcs.anl.gov/~balaji _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
