Votes and reading at MPI-Forum meeting March 13-16, 2023 (related to Terms and Topologies)
Dear MPI forum members, dear Wesley, in addition to my previous announcment, I would like to have the following issues (and their common PR 805) read: 235 Bindings - Shorten Example Index Names 607 Bindings - Add Example Titles 244 Bindings - Mark Erroneous Examples 610 Bindings - Fix Example Environment 633 Bindings - Update verbatim examples to example environment - All done together in the PR 805 https://github.com/mpi-forum/mpi-standard/pull/805/files I'll do final fixes and the pdf on next Monday before the 2-weeks-deadline. Special thanks to Bill Gropp for his great work on all his better formatting of the examples since 4.0 and marking the things that had to be fixed by the chapter committee. Best regards Rolf ----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Wesley Bland" <[email protected]> Sent: Thursday, February 16, 2023 7:50:12 PM Subject: Votes and reading at MPI-Forum meeting March 13-16, 2023 (related to Terms and Topologies)
I would like to have the following issues (and their PRs) voted or read.
================== 2nd votes related to MPI 4.1 ============== 641 Including Annex A.2 back into the standard Rolf 493 Issue N - Progress-Section in terms-2.tex Rolf 471 Fix Incorrect Usage of Rank/Task/etc. in Terms Chapter Rolf 565 Refer to Fortran 2018 instead of 2008+TS Rolf+Jeff H. 644 Update 'Process Topology' chapter title to use 'MPI process' Christoph
================== 1st votes related to MPI 4.1 ================= 543 'Pending operation' not defined, pending proper definition Rolf
================== Reading announcment =========================== 669 Add operation state 'enabled' and 'local calls' into Terms Rolf - Issue https://github.com/mpi-forum/mpi-issues/issues/669 - PR https://github.com/mpi-forum/mpi-standard/pull/788/files - PDF https://github.com/mpi-forum/mpi-standard/files/10758712/mpi41-report_Issue6...
================== Pre-Announcments for Reading ================== 586 MPI_Buffer_attach and Sessions Martin,Jeff,Rolf will first be discussed next week in the virtual MPI meeting Feb 22, 2023 - Issue https://github.com/mpi-forum/mpi-issues/issues/586 - PR https://github.com/mpi-forum/mpi-standard/pull/736/files - PDF https://github.com/mpi-forum/mpi-standard/files/10744036/mpi41-report_Issue5...
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany
participants (1)
Rolf Rabenseifner
