Re: [Mpi-forum] FTWG Readings for June 2016 Meeting
There was one update to the catastrophic error codes pull request since this morning. This is still inside the deadline so no votes will be necessary, but if you downloaded an earlier version of the text, you’ll need to update your pdf: issue-28-markup.pdf <https://github.com/mpi-forum/mpi-issues/files/278063/issue-28-markup.pdf> Thanks, Wesley
On May 22, 2016, at 9:00 PM, Bland, Wesley <[email protected]> wrote:
Hello Forum,
The Fault Tolerance Working Group would like to bring forward a number of proposals for a reading. All of these have been presented before and are being brought forward again after incorporating feedback from the forum. Even though some of these topics are divided into multiple issues, they will be read in three groups as shown below. Links to the issues and PDFs are also provided.
* Issue #28 / PR #9 - Add Catastrophic and Noncatastrophic Error Codes <https://github.com/mpi-forum/mpi-issues/issues/28> - issue-28-markup.pdf <https://github.com/mpi-forum/mpi-issues/files/276684/issue-28-markup.pdf> * Issues #1 & #3 / PR #1 - Define new MPI Error handler for subcommunicator abort <https://github.com/mpi-forum/mpi-issues/issues/3> - issue-1-markup.pdf <https://github.com/mpi-forum/mpi-issues/files/276697/issue-1-markup.pdf> * Issues #20, #21, #22 / PR #13 - User-Level Failure Mitigation <https://github.com/mpi-forum/mpi-issues/issues/20> - issue-20-21-22-anotated.pdf <https://github.com/mpi-forum/mpi-issues/files/155024/issue-20-21-22-anotated.pdf> Thanks, Wesley
participants (1)
Bland, Wesley
