Re: [Mpi-forum] MPI One-Sided Communication
On Fri, Apr 24, 2009 at 08:43:14PM -0400, Vinod tipparaju wrote:
Hmm. There are modules of NWChem that have datasets capable of scaling from 1s to 100's of thousands of cores.
Right. Those don't need a fast interconnect. They probably also would run fine with MPI-1. That's a solved problem; we don't need to think much about it.
You take a module that doesn't scale by its nature, say you prove that you can scale it with an incompatible model,
I was making a comment about how a difficult-to-scale but still interesting module could scale just fine with MPI-1. If Siosi6 isn't an interesting molecule and module then why is PNNL publishing benchmarks with it? http://www.emsl.pnl.gov/docs/nwchem/benchmarks/index.html Also, I don't see what you think is "incompatible." A PathScale employee wrote a modest patch to NWChem to use standard MPI-1 2-sided calls underneath the hood. I forget if the changes were at the GA level or the ARMCI level, but they didn't change the application at all.
and allowing NWChem to use 75% of compute power (try seeing your utilized flop rate)
As you can see, thanks to the better scaling, the utilized flop rate at large scale was better than the machine with real one-sided hardware. The graph is absolute performance, not scaling. The label on the Y axis makes that clear. Of course the cpus aren't exactly the same, but they are reasonably comparable, and that's the only data that was available to compare to. (BTW, that 75% could probably be improved, we never tested with other ratios.) I think this nicely illustrates my point that I don't know of any existing HPC application that really needs one-sided hardware to get great performance.* -- greg (* I'm not counting 1-sided-only apps from the intelligence community, of course.)
participants (1)
Greg Lindahl
