Re: [Mpi-forum] make check is busted!
Bill -- If we make minor changes in examples in the text, do we need to annotate them with "ticket 0" so that they can be ultimately voted on? On Jan 31, 2012, at 10:16 AM, William Gropp wrote:
Fab,
Yes, make check should build cleanly. For example, the errors in coll.tex are Fortran 90 subroutines, listed as complete routines, that are missing the required "END" statement. There are also "naked" examples that don't have the proper annotations; these should be added.
For those that don't know about the "make check" option - this makes sure that our examples don't have simple errors in them - it requires a small amount of work to add the necessary annotations (documented and examples exist throughout the source) and our experience has been that this catches a lot of errors that would otherwise be missed. In looking over the make check output, I see quite a few of those. Chapter authors should check their chapters.
Bill
On Jan 30, 2012, at 4:07 PM, Fab Tillier wrote:
Hey Folks,
Is it reasonable for me to expect that building the examples in the standard wouldn't generate a bunch of errors? Do we build the examples before publishing drafts, etc?
Just running 'make check' on the approved/MPI-3.0 branch gives me a bunch of errors, in the following files: - chap-one-side/one-side-2.tex - chap-context/context.tex - chap-coll/coll.tex - chap-binding/binding-2.tex - chap-topol/topol.tex - chap-prof/prof.tex
Can the chapter owners figure out how to either fix or suppress these errors? It makes it really hard to find errors I may have introduced - the signal to noise ratio is really lousy. Alternatively, is there a 'correct' way of running 'make check' that won't generate these? I ran autoconf in mpicompilechk, then configure. Should I be specifying extra parameters or anything?
Thanks, -Fab
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Jeff Squyres
