Re: [Mpi-forum] MPI-3: MPI_T_... names
I also agree to the name changes. Kathryn On 7/25/2012 2:59 AM, Bronis R. de Supinski wrote:
OK.
On Wed, 25 Jul 2012, Rolf Rabenseifner wrote:
After no objection by the tools chapter committee, I would change everywhere (tools + appLang) in one svn step:
- from old MPI_T_ERR_CANNOTINIT MPI_T_ERR_NOTINITIALIZED MPI_T_ERR_MEMORY MPI_T_ERR_CVAR_SETNOTNOW MPI_T_ERR_CVAR_SETNEVER MPI_T_ERR_PVAR_NOWRITE MPI_T_ERR_PVAR_NOSTARTSTOP MPI_T_ERR_PVAR_NOATOMIC MPI_T_ERR_INVALIDINDEX MPI_T_ERR_INVALIDITEM MPI_T_ERR_INVALIDSESSION MPI_T_ERR_INVALIDHANDLE MPI_T_ERR_OUTOFHANDLES MPI_T_ERR_OUTOFSESSIONS to new MPI_T_ERR_CANNOT_INIT MPI_T_ERR_NOT_INITIALIZED MPI_T_ERR_MEMORY (unchanged) MPI_T_ERR_CVAR_SET_NOT_NOW MPI_T_ERR_CVAR_SET_NEVER MPI_T_ERR_PVAR_NO_WRITE MPI_T_ERR_PVAR_NO_STARTSTOP MPI_T_ERR_PVAR_NO_ATOMIC MPI_T_ERR_INVALID_INDEX MPI_T_ERR_INVALID_ITEM MPI_T_ERR_INVALID_SESSION MPI_T_ERR_INVALID_HANDLE MPI_T_ERR_OUT_OF_HANDLES MPI_T_ERR_OUT_OF_SESSIONS
Best regards Rolf
----- Original Message -----
From: "Bronis R. de Supinski" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Tuesday, July 24, 2012 1:03:07 PM Subject: Re: [Mpi-forum] MPI-3: MPI_T_... names I have no strong opinion on this issue.
On Tue, 24 Jul 2012, Rolf Rabenseifner wrote:
I started a new email-trunk, because this mail is mainly about names.
The problem with MPI_T_... names is that they are partially very long:
Current longest MPI_T constants:
123456789012345678901234567890 MPI_T_PVAR_CLASS_HIGHWATERMARK (30) MPI_T_PVAR_CLASS_LOWWATERMARK (29) MPI_T_VERBOSITY_MPIDEV_DETAIL (29)
The system is classes of constants are named with underscores, e.g. MPI_T_PVAR_CLASS, the end-names without underscores, e.g. HIGHWATERMARK.
In the error codes, your right, they - should change from MPI_T_ERR_INVALIDINDEX MPI_T_ERR_INVALIDITEM MPI_T_ERR_INVALIDSESSION MPI_T_ERR_INVALIDHANDLE to MPI_T_ERR_INVALID_INDEX MPI_T_ERR_INVALID_ITEM 123456789012345678901234567890 MPI_T_ERR_INVALID_SESSION (25) MPI_T_ERR_INVALID_HANDLE because the class name is MPI_T_ERR_INVALID_
- and also MPI_T_ERR_OUTOFHANDLES MPI_T_ERR_OUTOFSESSIONS to MPI_T_ERR_OUT_OF_HANDLES MPI_T_ERR_OUT_OF_SESSIONS - and they may change MPI_T_ERR_CANNOTINIT MPI_T_ERR_NOTINITIALIZED MPI_T_ERR_MEMORY MPI_T_ERR_CVAR_SETNOTNOW MPI_T_ERR_CVAR_SETNEVER MPI_T_ERR_PVAR_NOWRITE MPI_T_ERR_PVAR_NOSTARTSTOP MPI_T_ERR_PVAR_NOATOMIC to MPI_T_ERR_CANNOT_INIT MPI_T_ERR_NOT_INITIALIZED MPI_T_ERR_MEMORY MPI_T_ERR_CVAR_SET_NOT_NOW MPI_T_ERR_CVAR_SET_NEVER MPI_T_ERR_PVAR_NO_WRITE 123456789012345678901234567890 MPI_T_ERR_PVAR_NO_STARTSTOP (27) MPI_T_ERR_PVAR_NO_ATOMIC
All the other MPI_T_... names seem to be fine.
Bets regards Rolf
From: "Alexander Supalov" <[email protected]> To: "Martin Schulz" <[email protected]>, "Main MPI Forum mailing list" <[email protected]> Sent: Tuesday, July 24, 2012 9:35:13 AM Subject: Re: [Mpi-forum] MPI-3: MPI_T_ERR_... and MPI_ERR_LASTCODE Hi everybody,
I see that that my innocent remarks re. Annex A have lead to a lot of discussion. What I'm going to say may resemble Bart Simpson's "I didn't do it", but I think I have to:
When commenting on the MPI_T_* names, I meant only their composition that differed from most other comparable MPI constant names in that it was 1) using contractions and 2) not using underscores to separate different words. The MPI_T_CANTINIT was but one example of this. I proposed to change all MPI_T_* names to follow the more traditional rules (i.e., 1) do not use contractions and 2) do use underscores), which lead to the MPI_T_CANNOT_INIT proposal that should be consistently followed up on for every other MPI_T_* name. The MPI_ERR_LASTCODE was mentioned as a counterexample of a known MPI constant name that was not following this set of rules either. Oh well, this is an old one and we won't change it. At no time did I intend the MPI_T series to become a part of the MPI_ERR series, although I must admit that they look really close when you start thinking about them. We will probably have enough time for this contemplation in the MPI 3.1 time frame.
To sum up, my proposal now is:
1) Consider replacing contractions in all MPI_T_* names 2) Consider using underscores in all MPI_T_* names 3) Drop the MPI_ERR and MPI_T connection idea
And if 1) and 2) are considered too invasive at this point, I won't go nuts either: after all, these are just constant names.
Best regards.
Alexander
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
_____________________________________________________________________ Kathryn Mohror, [email protected], http://people.llnl.gov/mohror1 CASC @ Lawrence Livermore National Laboratory, Livermore, CA, USA
participants (1)
Kathryn Mohror
