Re: [Mpi-forum] Vote announcement for the May 2023 meeting of the MPI Forum
Dear forum members, I would like to make the following announcements for the next MPI Forum Meeting (May 2-5, 2023): - 2nd votes on #669 Add operation state 'enabled' and 'local calls' into Terms Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/669 PR https://github.com/mpi-forum/mpi-standard/pull/788 #457 Improvements around the word "rank" in the Process Topologies chapter Christoph,Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/457 PR https://github.com/mpi-forum/mpi-standard/pull/804 #485 Fix Incorrect Usage of Rank/Task/etc. in Language Bindings Chapter Rolf,Puri Issue https://github.com/mpi-forum/mpi-issues/issues/485 PR https://github.com/mpi-forum/mpi-standard/pull/803 PDF https://github.com/mpi-forum/mpi-standard/files/10831598/mpi41-report_Issue4... - errata reading and vote on #679 Errata: Noncollective (for procedure) and nonpersistent are not defined Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/679 PR https://github.com/mpi-forum/mpi-standard/pull/820 PDF https://github.com/mpi-forum/mpi-standard/files/11432286/mpi41-report_Issue6... - pre-announcement for errata reading and vote on --> See also virtual meeting, June 7, 2023 !!! #705 Errata: Fortran has only compile-time constants Rolf,Joseph Issue https://github.com/mpi-forum/mpi-issues/issues/705 (together with https://github.com/mpi-forum/mpi-issues/issues/657 Rolf, Jeff H.) PR https://github.com/mpi-forum/mpi-standard/pull/822 #710 Errata: 'Pending communication' not defined in MPI_Comm_disconnect Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/710 PR https://github.com/mpi-forum/mpi-standard/pull/823 #676 Errata: 'Pending operation' not defined, pending proper definition Rolf,Joseph Issue https://github.com/mpi-forum/mpi-issues/issues/676 PR https://github.com/mpi-forum/mpi-standard/pull/824 Best regards Rolf Rabenseifner -- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany
participants (1)
Rolf Rabenseifner
