Re: [Mpi-forum] cancel in standard
Right now, there is no concept of "MPI-3.2" -- there's only MPI-3.1 errata and MPI-4.0.
On Jun 5, 2015, at 12:47 PM, Balaji, Pavan <[email protected]> wrote:
I've changed the latter two to "MPI-next".
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
On 6/5/15, 11:43 AM, "Bland, Wesley" <[email protected]> wrote:
The version information should probably be updated for the tickets that you are targeting for MPI 3.2 and MPI 4.0. Right now, they’re all MPI 3.1 errata.
On June 5, 2015 at 11:29:58 AM, Balaji, Pavan ([email protected]<mailto:[email protected]>) wrote:
FYI, here are the three tickets mentioned below. Feedback is appreciated. I'll pass this through the pt2pt working group, but I'm looking for general feedback at this point.
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/478
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/479
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/480
-- Pavan
On 6/5/15, 7:08 AM, "mpi-forum on behalf of Balaji, Pavan" <[email protected] on behalf of [email protected]> wrote:
One of the main reasons cancel send was introduced was for symmetry, since there were cancel receives too. But that argument has gone out the window with NBC, RMA and I/O requests which are all not cancelable.
For everyone's information, we are working on three tickets.
1. An MPI-3.1 errata ticket to clarify the wording in the MPI standard as to what cancel send must do. This will also remove some incorrect wording in the standard with respect to the behavior of wait/test after a failed cancelation.
2. An MPI-3.2 ticket to deprecate send cancel citing all the complexities in implementing it efficiently. More importantly the cost of supporting send cancel on non-cancel operations.
3. An MPI-4.0 ticket to remove send cancel.
-- Pavan
Sent from my iPhone
On Jun 5, 2015, at 3:16 AM, Supalov, Alexander <[email protected]> wrote: br/>>> Just a note: MPI__Cancel would be next to MPI_ANY SOURCE to go had one introduced assertions. :) br/>>> -----Original Message----- < From: mpi-forum [mailto:[email protected]] On Behalf Of William Gropp Sent: Thursday, June 4, 2015 2:24 PM To: Main MPI Forum mailing list Subject: Re: [Mpi-forum] cancel in standard br/>>> But the user did care about it, and theey decided to cancel it. It may not be one message, but one per iteration. And the semantics is clear (even if the standard's language isn't). br/>>> Bill < br/>>>> On Jun 3, 2015, at 10:08 PM, Jeff Hammond <[email protected]> wrote:
br/>>>> What's the harm in letting a meessage that the user clearly does not br/>>>> care about sitt in a queue/buffer forever? I consider this an br/>>>> aacceptable consequence of a really stupid feature. br/>>>> Jeff < br/>>>>> On Wed, Jun 3, 2015 at 9:550 PM, William Gropp <[email protected]> wrote:
Pavan is correct about the intent, and we could make this more precise. The basic requirement is that a message is *guaranteed* to either be canceled (on send) or received. Sitting in a queue or buffer somewhere does not count. br/>>>>> Bill < br/>>>>>> On Jun 3, 2015, att 7:19 PM, Balaji, Pavan <[email protected]> wrote:
br/>>>>>> br/>>>>>> [[Cc'ed the Forum] br/>>>>>> This wording haas been debated many times at the Forum. Specifically, the "completes normally" and "received at the destination" pieces are ambiguous. For instance, if the data is copied into a bounce buffer, the send would complete normally, but that does not mean that there is a receive posted for that data. In this case, it would be the user's responsibility to post a corresponding receive. If the MPI implementation does not have a bounce buffer (e.g., for large messages), "received at the destination" could mean into an unexpected buffer, not necessarily a user buffer. br/>>>>>> The consensus ffrom MPI-1 veterans (Marc, Bill, etc.) during the last discussion was that if the application does not post a receive, then it is guaranteed that the send should be cancelable. At least that was the intent. The wording, of course, is too vague for such a definition. br/>>>>>> You could try tto weaken that interpretation and say that if the MPI implementation is not able to cancel a send operation, then the user is responsible for posting a matching receive to receive that data. Irrespective of which interpretation we go with, I think it is important to clarify it in the standard. Perhaps an MPI-3.1 errata or MPI-3.2 change instead of waiting for MPI-4? Do you want to create a ticket? br/>>>>>> -- Pavan < br/>>>>>> br/>>>>>> br/>>>>>> br/>>>>>>> On 6/3/15, 7:05 PM, ""Sur, Sayantan" <[email protected]> wrote:
br/>>>>>>> What liines in the standard support the interpretation that "a br/>>>t;>>>> message that will not be successfully matched, must be cancelable"? br/>>>>>>> This iss what I found, and it doesn't support the stricter interpretation. br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> br/>>>>>>> ""If a send is marked for cancellation, then it must be the case that br/>>>>>>> either the send ccompletes normally, in which case the message sent br/>>>>&ggt;>> was received at the destination process, or that the send is br/>>>>>>> successfully cancelled, in which case noo part of the message was br/>>>>>>> received at thhe destination. Then, any matching receive has to be br/>>>>;>>> satisfied by another send."
mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum br/>>>>> ________________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum br/>>>> br/>>>> br/>>>> -- < Jeff Hammond [email protected] http://jeffhammond.github.io/
mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum br/>>> ________________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen, Deutschland Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Christian Lamprechter, Hannes Schwaderer, Douglas Lusk Registergericht: Muenchen HRB 47456 Ust.-IdNr./VAT Registration No.: DE129385895 Citibank Frankfurt a.M. (BLZ 502 109 00) 600119052 br/>>> ________________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Jeff Squyres (jsquyres)
