large count support not as easy as people seem to have thought
As I noted on this list last Friday, I am working on a higher-level library to support large counts for MPI communication functions (https://github.com/jeffhammond/BigMPI). In the course of actually trying to implement this the way the Forum contends it can be done - i.e. using derived-datatypes - I have found some issues that undermine the Forum's contention that it is so easy for users to do it that it doesn't need to be in the standard. To illustrate some of the issues that I have found, let us consider the large-count implementation of nonblocking reduce... # Example Use Case It is entirely reasonable to think that some quantum chemist will want to reduce a contiguous buffer of more than 2^31 doubles corresponding to the Fock matrix if they have a multithreaded code, since 16 GB is not an unreasonable amount of memory per node. # Issues Unlike the blocking case, where it is reasonable to chop up the data and performance multiple operations (e.g. https://github.com/jeffhammond/BigMPI/blob/master/src/reductions_x.c, assuming that untested code is correct), one must return a single request to the application if one is to implement MPIX_I(all)reduce_x with the same semantics as MPI_Iallreduce, as I aspire to do in BigMPI. Issue #1: chopping doesn't work for nonblocking. To do the large-count reduction in one nonblocking MPI call, a derived datatype is required. However, unlike in RMA, reductions cannot use built-in ops for user-defined datatypes, even if they are trivially composed of a large-count of built-in datatypes. See https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/338 and https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/34 for elaborate commentary on why this semantic mismatch is lame. Issue #2: cannot use built-in reduce ops. Once we rule out using built-in ops with our large-count datatypes, we must reimplement all of the reduction operations required. I find this to be nontrivial. I have not yet figured out how to get at the underlying datatype info in a simple manner. It appears that MPI_Type_get_envelope exists for this purpose, but it's a huge pain to have to call this function when all I need to know is the number of built-in datatypes so that I can apply my clever and use MPI_Reduce_local inside of my user-defined operation. Issue #3: implementing the user-defined reduce op isn't easy (in my opinion). Many MPI implementations optimize reductions. On Blue Gene/Q, MPI has explicitly vectorized intrinsic/assembly code. Unless MPI_Reduce_local hits that code path, I am losing a huge amount of performance in reductions when I go from 2^31 to 2^31+1 elements. I would not be surprised at all if user-defined ops+datatypes exercises suboptimal code paths in many MPI implementations, which means that the performance of nonblocking reductions is unnecessarily crippled. Issue #4: inability to use optimizations in the MPI implementation. # Conclusion I believe this problem is best addressed in one of two ways: 1) Approve the semantic changes requested in tickets 34 and 338 so that one can use built-in ops with homogeneous user-defined datatypes. This is my preference for multiple reasons. 2) Add large-count reductions to the standard. This means 8 new functions: blocking and nonblocking (all)reduce and reduce_scatter(_block). We don't need large-count functions for any other collectives because the datatype solution works just fine there, as I've already demonstrated in BigMPI (https://github.com/jeffhammond/BigMPI/blob/master/src/collectives_x.c). # Social Commentary
From now on, when the Forum punts on things and says it's no problem for users to roll their own using the existing functionality in MPI, we should strive to be a bit more diligent and actually prototype that implementation in a manner that proves how easy it is for users. It turns out, writing code for some things is harder than just talking about them in a conference room...
# Related https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/338#comment:9 captures some of this feedback in Trac. I created https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/423 for the reasons described therein. -- Jeff Hammond [email protected]
participants (1)
Jeff Hammond
