Re: [Mpi-forum] Big Fortran hole in MPI-4.0 Embiggening
Dear Jeff and all,
I think their users would be very unhappy.
Yes, users can be unhappy and compute centers may definitely recommend an other MPI library - at least for any software development. I want to remember that MPI-3.1 requires for the mpi module: "Provide explicit interfaces according to the Fortran routine interface specications. This module therefore guarantees compile-time argument checking and allows positional and keyword-based argument lists. If an implementation is paired with a compiler that either does not support TYPE(*), DIMENSION(..) from TS 29113, or is otherwise unable to ignore the types of choice buffers, then the implementation must provide explicit interfaces only for MPI routines with no choice buer arguments. See Section 17.1.6 for more details." Although there are no more such compilers that do not provide one of the two methods, there are more than 5 years after MPI-3.1 still MPI libraries that do not provide keyword-based argument lists with the mpi module. And those libraries provide such support for the mpi_f08 module. This means, they prove that they are not MPI-3.1 compliant :-) Sometimes implementors ignore the goals and the wording of the MPI standard. And there is also no request that users want to have a less-quality mpi module definition. Best regards Rolf ----- Original Message -----
From: "Main MPI Forum mailing list" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Jeff Squyres" <[email protected]> Sent: Sunday, January 10, 2021 5:09:55 PM Subject: Re: [Mpi-forum] Big Fortran hole in MPI-4.0 Embiggening
I can't imagine a vendor would:
- support mpi_f08 - then stop supporting mpi_f08 just so that they can get an "MPI-4.0" release out - then support mpi_f08 again
On Jan 10, 2021, at 10:55 AM, William Gropp via mpi-forum < [ mailto:[email protected] | [email protected] ] > wrote:
I agree with Dan that this is a big change from the RCM. Further, the approach in MPI has always been to encourage the users to make it clear to the vendors what is acceptable in implementations, especially implementation schedules. Nothing in the standard prohibits implementors from continuing to provide MPI 3.x implementations while they work to provide a full MPI 4.0 implementation. The MPI forum has no enforcement power on the implementors, and I believe this text is unnecessary and will not provide the guarantee that Rolf wants. Further, frankly once the C embiggened interface is implemented, creating the mpi_f08 version is relatively straightforward.
Bill
William Gropp Director, NCSA Thomas M. Siebel Chair in Computer Science University of Illinois Urbana-Champaign IEEE-CS President-Elect
On Jan 10, 2021, at 7:44 AM, HOLMES Daniel via mpi-forum < [ mailto:[email protected] | [email protected] ] > wrote:
Hi Rolf,
This is a (somewhat contrived, arguably) reason for taking another tiny step towards removing the “mpif.h” method of Fortran support and pushing users and implementations towards preferring the Fortran 2008 interface, which is a direction of travel that I fully support.
I think this might be seen as quite a big change for implementers, especially if it were to occur between the RCM and FRM.
Cheers, Dan. — Dr Daniel Holmes PhD Architect (HPC Research) [ mailto:[email protected] | [email protected] ] Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 2.09, Bayes Centre, 47 Potterrow, Central Area, Edinburgh, EH8 9BT — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. —
On 10 Jan 2021, at 12:22, Rolf Rabenseifner via mpi-forum < [ mailto:[email protected] | [email protected] ] > wrote:
This email was sent to you by someone outside the University. You should only click on links or attachments if you are certain that the email is genuine and the content is safe.
Dear MPI-Forum members,
MPI-3.1 and MPI-4.0 includes the following rule on top of the 2nd page of the Language Binding chapter:
| MPI implementations providing a Fortran interface must provide | one or both of the following: | - The USE mpi_f08 Fortran support method. | - The USE mpi and INCLUDE 'mpif.h' Fortran support methods.
The embiggening was included only in the C and mpi_f08 bindings.
Most implementors nowadays provide all three MPI Fortran support methods, i.e., the mpi_f08 and the mpi module and mpif.h.
For all MPI-3.1 libraries that provide all three MPI Fortran support methods, the most easiest and fastest way to provide MPI-4.0 for C and Fortran is, - to implement the embiggening for C, - and to remove the mpi_f08 module, - and maybe months or years later, to provide mpi_f08 again, now embiggened.
This implementation path (by removing mpi_f08 from MPI-3.1 and to name it MPI-4.0 without Fortran embiggening) was of course never intended, when we decided to require the embiggened routines only for mpi_f08. The goal was - to not require additional work from the implementors for the old mpi module - convince the users that it is a good idea to make a transition to mpi_f08.
The most simplest way to resolve this problem would be to require mpi_f08 for MPI-4.0, i.e., to change the text to
| MPI implementations providing a Fortran interface | - must provide the USE mpi_f08 Fortran support method, | - and additionally may provide both, | the USE mpi and INCLUDE 'mpif.h' Fortran support methods.
What is your opinion?
I expect that we should discuss this next Wednesday at our MPI Forum telcon.
Best regards Rolf
-- Dr. Rolf Rabenseifner . . . . . . . . . .. [ mailto:[email protected] | email [email protected] ] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . [ https://urldefense.com/v3/__http://www.hlrs.de/people/rabenseifner__;!!DZ3fj... | www.hlrs.de/people/rabenseifner ] . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpi-forum mailing list [ mailto:[email protected] | [email protected] ] [ https://urldefense.com/v3/__https://lists.mpi-forum.org/mailman/listinfo/mpi... | https://lists.mpi-forum.org/mailman/listinfo/mpi-forum ]
_______________________________________________ mpi-forum mailing list [ mailto:[email protected] | [email protected] ] [ https://urldefense.com/v3/__https://lists.mpi-forum.org/mailman/listinfo/mpi... | https://urldefense.com/v3/__https://lists.mpi-forum.org/mailman/listinfo/mpi... ]
_______________________________________________ mpi-forum mailing list [ mailto:[email protected] | [email protected] ] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
_______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) .
participants (1)
Rolf Rabenseifner
