Re: [Mpi-forum] Ticket 125/126 PDF ready for review
I think it looks ok, meaning that I checked your changes. I did not check to see if you missed any. That being said, I'm not a fan of the MPI_INIT_THREAD C declaration -- it seems to just be more confusing than using ***. Specifically, it's: int MPI_Init_thread(int *argc, char *((*argv)[]), int required, int *provided) Personally, I think *** is cleaner/easier to understand: int MPI_Init_thread(int *argc, char ***argv, int required, int *provided) I would advocate changing MPI_Init_thread to *** rather than changing MPI_Init to the complicated [] syntax. On Jan 20, 2012, at 2:17 PM, Fab Tillier wrote:
Hi Folks,
I've implemented the changes to the standard document for tickets 125 and 126. The PDF is attached to the ticket, and available here: https://svn.mpi-forum.org/trac/mpi-forum-web/raw-attachment/ticket/125/ticke...
A couple notes where I deviated from the tickets: - I didn't distinguish between input and output parameter changes, so all the changes are marked as ticket125 - I did not add 'const' for the input parameters, as that was already done by ticket 140 - I only updated the C bindings - I did not update MPI_Type_hindexed and MPI_Type_struct in the deprecated chapter. - I updated MPI_Init to match the parameter definition of MPI_Init_thread.
I'd appreciate if folks could take a look and comment, letting me know if I botched anything, or missed anything that should be changed.
Thanks, -Fab
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
Jeff Squyres
