Compile-time check for MPI_Init or MPI_Init thread
Hi all, we are currently puzzled about how to check whether to call MPI_Init or MPI_Init_thread in one of our programs. Our performance analyzer scout can be built in different versions: MPI, OpenMP, and hybrid MPI/OpenMP. As the code-base is shared, we have #define statements to separate individual portions of the code. To decide whether to call MPI_Init or MPI_Init_thread at compile time we check the #define set by MPI. However, POE on our Power6 Cluster correctly reports MPI 1, as it does not support spawning and is therefore not MPI 2 compliant, yet MPI_Init_thread would be available, and must be used for the hybrid version. My initial idea is to take 'nm' at configure-time of our tool. Check whether MPI_Init_thread is in the library, and set my own #define. Is there a more elegant solution? How are users supposed to portably detect it? Is it something we can/should fix? Best regards, Marc-Andre -- Marc-Andre Hermanns Juelich Supercomputing Centre Institute for Advanced Simulation Forschungszentrum Juelich GmbH D-52425 Juelich Germany Phone : +49-2461-61-2054 Fax : +49-2461-61-6656 eMail : [email protected] WWW : http://www.fz-juelich.de/jsc/ JSC is the coordinator of the John von Neumann Institute for Computing and member of the Gauss Centre for Supercomputing Sitz der Gesellschaft: Juelich Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498 Vorsitzende des Aufsichtsrats: MinDir'in Baerbel Brumme-Bothe Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender), Dr. Ulrich Krafft (stellv. Vorsitzender), Prof. Dr. Harald Bolt, Prof. Dr. Sebastian M. Schmidt
participants (1)
Marc-Andre Hermanns
