Re: [Mpi-forum] MPI One-Sided Communication
<sigh> I meant the copy in the application that comes before MPI is called. A lot of apps don't have all of the data they want to send in a contiguous buffer. And, yes, derived datatypes can help this, but aren't commonly used and still involve a copy on a lot of hardware. Keith ----- Original Message ----- From: [email protected] <[email protected]> To: Main MPI Forum mailing list <[email protected]> Sent: Mon Apr 27 06:32:53 2009 Subject: Re: [Mpi-forum] MPI One-Sided Communication On Apr 27, 2009, at 9:14 AM, Underwood, Keith D wrote:
For many (most?) science and engineering codes, the trade-off between matching for two sided and synchronization for one sided is at best a wash, and often would fall in favor of two sided. There is, of course, an exception....
If one sided delivered truly stellar performance in terms of message rate and latency, you could (in some cases) eliminate the cost of the copy at the sender that is tyically done to send long messages to cover the overhead. The hardware to deliver that level of performance is truly rare...
Keith
"cost of the copy at the sender that is tyically done to send long messages to cover the overhead" ? Typically, any HPC NIC uses zero-copy for large messages. Copy is only used for small messages (where small depends on the fabric/NIC/ software stack). It is even possible to avoid copy on send for large messages over standard Ethernet using sendfile() and other options. Scott _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
Underwood, Keith D
