Re: [Mpi-forum] Missing array size information in MPI_WAITSOME and MPI_TESTSOME
I agree that it isn't very clear, but I would use the following as my guide for what the length of array_of_statuses needs to be: "The error-free execution of MPI_WAITALL(count, array_of_requests, array_of_statuses) has the same effect as the execution of MPI_WAIT(&array_of_request[i], &array_of_statuses[i]), for i=0 ,..., count-1, in some arbitrary order. MPI_WAITALL with an array of length one is equivalent to MPI_WAIT." [top of page 60 in mpi22-report.pdf] Furthermore: "When one or more of the communications completed by MPI_WAITSOME fails, then it is desirable to return specific information on each communication. The arguments outcount, array_of_indices and array_of_statuses will be adjusted to indicate completion of all communications that have succeeded or failed." [bottom of page 61 in mpi22-report.pdf] One has to assume that all communications could succeed or fail prior to a call to MPI_WAITSOME, therefore, one has to provide an array of length incount. It does bother me that "The arguments outcount, array_of_indices and array_of_statuses will be adjusted to indicate completion of all communications that have succeeded or failed," does not scope how the implementation may adjust these arguments. Is it permitted to call realloc and shrink array_of_indices and array_of_statuses? If the arguments are OUT, does one even have to allocate memory for them, or will the implementation test for nullity and allocate the memory internally? So yeah, I think you've identified a problem, but I only read the text twice. Some parts of the standard have to be read at least ten times in a variety of mental states before they can be understood. I found that heavy use of peyote was necessary to understand the RMA chapter :-) Best, Jeff On Sun, Feb 26, 2012 at 12:53 PM, Jeremiah Willcock <[email protected]> wrote:
The documentation in the MPI 2.2 standard and the latest public 3.0 draft do not say how long the output arrays array_of_indices and array_of_statuses should be, and the example there does not show the declarations of the arrays that it passes in. �A reader can probably infer that they need to be at least incount elements long, but that is not obvious from the text.
-- Jeremiah Willcock _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/old/index.php/User:Jhammond https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
participants (1)
Jeff Hammond
