Question about MPI_Alloc_mem
Folks, I know we have had this function for a long time, and I've implemented ports of MPI that actually use it (e.g., with pre-pinned memory). But, I am trying to understand the logic for why baseptr is passed by value, instead of by reference. In C, everything is by value, so the last argument in normal C programs would be void **baseptr. The standard has: int MPI_Alloc_mem(MPI_Aint size, MPI_Info info, void *baseptr); Now, MPICC/GCC takes this with void *memory = (void *)0; int error = MPI_Alloc_mem(1024, MPI_INFO_NULL, &memory); and you get the memory allocated properly. What is more, this is incorrect: int error = MPI_Alloc_mem(1024, MPI_INFO_NULL, memory); although it compiles fine because that is, indeed, the API. Why would we have the pointer going in by value, when it is coming out as an OUT argument? Isn't this plain wrong? void **baseptr means ---> I am passing you the address of a void pointer. Every viable implementation must do *(void **)baseptr = ... when providing the "malloc'd/special" memory. So... why did we fudge the C API. Is there some tie-in with the Fortran API? Thanks in advance, Tony Skjellum -- Anthony Skjellum, PhD [email protected] Cell: +1-205-807-4968
participants (1)
Anthony Skjellum
