Re: [Mpi-forum] Reserved MPI_ prefix & namespace in C and Fortran
Bronis, Yes, my erratum must also fix MPI-2.2 2.6.4 p18:40-41 in the same way as C. I added it below. Rolf ----- Original Message -----
From: "Bronis R. de Supinski" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Friday, August 24, 2012 6:38:57 PM Subject: Re: [Mpi-forum] Reserved MPI_ prefix & namespace in C and Fortran I'm not a C++ expert but my understanding is that "MPI_" is not all that you want reserved there. I think you also what to reserve "MPI::". Does it matter?
On Fri, 24 Aug 2012, Rolf Rabenseifner wrote:
Bill,
good idea. I try it; what about
C:
"Programs must not declare names (identifiers), e.g., for variables, functions, constants, macros, types, or namespaces, beginning with the prefix MPI_."
Fortran:
"Programs must not declare names, e.g., for variables, parameters, functions, derived types, or abstract interfaces, beginning with the prefix MPI_.
C++
in the namespace MPI."
Rolf
From: "William Gropp" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Friday, August 24, 2012 6:05:38 PM Subject: Re: [Mpi-forum] Reserved MPI_ prefix & namespace in C and Fortran The intent of the Forum has always been that all names that begin with MPI_ or PMPI_, and the MPI namespace, are reserved for MPI. The mistake (a common one) was to attempt to enumerate all of the items to which this applies. Rather than attempt to cover everything, I would prefer changing the text to match the indent; it can mention specific categories as examples but should not attempt to list them, as this is always error prone.
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
On Aug 24, 2012, at 10:31 AM, Rolf Rabenseifner wrote:
Dear all,
Jeremiah detected a very old inconsistency in the MPI standard:
On page 19 line 14, the restriction on use of MPI_* names should also apply to preprocessor macros, namespaces in C++, types, and other things.
In MPI-2.2, it was page 18, lines 15-16:
"Programs must not declare variables or functions with names beginning with the prefix MPI_."
Together with MPI-2.2 p4:26
"Any correct MPI-2.1 program is a correct MPI-2.2 program."
and the new constant declaration on p258:17: MPI_DIST_GRAPH, the implication is that the MPI standard is inconsistent.
The solution is very simple, an MPI-2 errata ticket changing MPI-2.2, lines 15-16 into (addition marked with {...}):
"Programs must not declare variables, functions, { constants, macros, types, or namespaces } with names beginning with the prefix MPI_."
And for Fortran on p17:41-42 (addition marked with {...}):
"Programs must not declare variables, parameters, functions, { derived types, or abstract interfaces } with names beginning with the prefix MPI_.
It should be a single reading+vote errata ticket, because it does not change the standard, it only makes it obvious. The reservation was in MPI-2.1 in fact already there through the sentence
because nobody could foresee, which new things we will have added to MPI-2.2.
Details are in ticket https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/343
And see markups ticket0.343 on page 11 in https://svn.mpi-forum.org/trac/mpi-forum-web/attachment/ticket/343/ticket0.3...
I hope that there is a broad consensus to solve this inconsistency.
Best regards Rolf
From: "Jeremiah Willcock" <[email protected]> To: [email protected] Sent: Sunday, August 19, 2012 2:13:41 AM Subject: [Mpi-comments] Comments on MPI 3.0 draft 2 These are in reference to the draft at <URL:http://meetings.mpi-forum.org/mpi3.0_draft_2.pdf>. Thank you for considering them.
-- Jeremiah Willcock ... On page 19 line 14, the restriction on use of MPI_* names should also apply to preprocessor macros, namespaces in C++, types, and other things.
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
Rolf Rabenseifner
