Re: [Mpi-forum] Other tickets and Re: Upcoming formal readings
At this stage the agenda is over full - we will not be taking on any more items. We will discuss how to proceed at the next meeting. Given that we have on the order of 13 formal readings, and quite a few of them coming up for the first real attempt at a formal reading, it is likely that many of these will need to go through a second re-read, at a minimum. As a group we will need to decide if we want to delay 3.0 by 1 or 2 meetings, or if we stick to the original list of the top 3 items to be added into MPI 3.0, and when these are done, 3.0 is out the door, with other items following in 3.1. So, there MAY be some time to get some of these smaller items in. For ticket 0 type of items, there is no issue - we still have time. Rich On Jan 5, 2012, at 1:00 PM, Rolf Rabenseifner wrote:
Rich and all ticket owners,
is it correct that in/for the following tickets, the ticket-priority and/or the agenda should be updated:
#187 (MPI_AINT, MPI_OFFSET, MPI_COUNT in reductions, etc.) should be set to scheduled for reading in Jan. 2012
#271 (MPI_Info for comm and win) --> "scheduled" (for Jan 2011)
On Dec. 21, Adam Moody asked for 15 Min. formal reading
#273 (nonbl. coll. I/O) is in state "scheduled" but not yet on the agenda
#275 (Minor corrections to new RMA Chapter) lists one bug but seems to be overseen (never read, not scheduled, ...)
#285 (nonbl. coll. file manipulation) was read in Oct. 2011, but is not yet in state "had 1st reading"
I expect that voting should be delayed until #273 is read.
#289 (MPI_Comm_merge) is related to #310 + #311 ? It was presented at Santorini (Sep. 2011). Was it formally read? Should it be?
#294 (MPI_UNWEIGHTED should not be NULL) --> "had 1st reading" (Oct. 2011) and should be scheduled for a 1st vote in Jan 2012.
As far as I remember, the content is correct and read without any comment.
#308 + #309 (RMA) are in state "scheduled" and on the agenda, but not mentioned for a "formal reading"
What are we doing with the following tickets that are not fully ready: ----------------------------------------------------------------------
#125 Use of [] in output arrays ("trivial text changes")
#126 Consistent use of [] for input arrays
What are we doing with the following tickets that can be directly read+voted: -----------------------------------------------------------------------------
#158 Clarification that MPI_Cart_map and MPI_Graph_map are local calls
#162 MPI 2.1 Clarification - MPI_Cart_map with num_dims=0
#185 Mention C++ typedef deprecations
#218 "same arguments" to MPI_Reduce
#219 MPI_MAX_OBJECT_NAME and MPI_Type/win_get_name
#227 Clarify ambiguous sentence for MPI_FINALIZE
#259 Text updates for MPI_DIST_GRAPH
What are we doing with the "trivial text changes": --------------------------------------------------
#207 Minor Text Correction / MPI_GET_PROCESSOR_NAME
#215 MPI-2.2 typo - missing parenthesis on page 272, line 25
#216 Remove extra fullstop
#254 Typo in the description of MPI_GROUP_INCL
#255 Missing headline for MPI_GET_PROCESSOR_NAME
#260 Copy-paste error in point to point chapter
#262 Minor typos in pt2pt chapter
#267 Typo in One-Sided chapter 11.4.4
#268 Formatting issue in One-Sided chapter 11.4.4
If one of these groups needs less than "reading + 2 votes", then they may be already now scheduled for the March 2012 meeting, to make clear that we are processing them.
Best regards Rolf
----- Original Message -----
From: "Jeff Squyres" <[email protected]> To: "MPI Forum list" <[email protected]> Sent: Tuesday, January 3, 2012 4:58:39 PM Subject: [Mpi-forum] Upcoming formal readings If you have a formal reading next week, please be sure to do the following (if you have not already done so):
- you have a ticket for each formal reading next week - the ticket's milestone is set to "2012/01/09 California, USA" - the ticket's priority is set to "Scheduled" - the PDF that will be read is either attached or directly linked to from the ticket
Since there are *sooo* many readings, this will make it significantly easier for the rest of the Forum to find all the PDFs that we're supposed to read by next week.
Thanks!
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Graham, Richard L.
