Re: [Mpi-forum] Feb 2021 MPI Forum Meeting Plan
Hi Rolf, Comments inline marked with ">>" Martin -- Prof. Dr. Martin Schulz, Chair of Computer Architecture and Parallel Systems Department of Informatics, TU-Munich, Boltzmannstraße 3, D-85748 Garching Member of the Board of Directors at the Leibniz Supercomputing Centre (LRZ) Email: [email protected] On 23.02.21, 09:53, "mpi-forum on behalf of Rolf Rabenseifner via mpi-forum" <[email protected] on behalf of [email protected]> wrote: Dear Wesley and all, Wesley, you did yesterday a wonderful job. Please do not take the following items as any critism on your work. they are only on procedural/general problems we may have. 1. Can it be that one No-No-vote can influence the outcome of the MPI standard when the majority does not see a problem with the text?
Yes, that is correct - if a No-No fails, then we vote on whether to advance the standard without that PR.
We may procedurally gave and still give no-no-voters to much influence on the text.
To some degree, yes, but this is supposed to be a last stop-gap measure and then we do, of course, folks to act reasonable with the consequences, which - so far - has worked IHMO.
I hope that this - will not happen during this meeting
To be honest, I wouldn't be surprised if it did, and probably not without reason.
- and if it happens then I hope that the FRM is changed to a RC
That's why we will have that vote on a different day - when we vote on the whole standard, everyone will have seen what had been voted in and what out and has the ability to vote accordingly. Personally, I hope as well that, if we find problems and we reject additions that are impactful, that a majority would vote for another round for the FRM.
- and therefore the exactly same PR is then voted with a normal erata-vote into the standard on the next meeting.
That is technically correct, but I would hope that we can fix issue that are brought up so that the concerns of the few no/no votes are met after the changes. Note that we do not have to fix them this week (would be good if we do, but not required), but we need to add them to the list of fixes needed. So far, from the issues that are noted on the list, I would think that we can achieve agreement on all of them before June. We'll see - I am an eternal optimist __.
2. My aplogies that -- also I was prepared to catch it -- I oversaw the moment when the folowing text change was presented: RC 1 Example 5.22 An elaborate example. int position, i; float a[1000]; char buff[1000]; changed in RC 2 Example 5.22 An elaborate example. int position, i = 200; Correct float a[200]; Correct char buff[1000]; /* larger than sizeof(int) + 200 * sizeof(float) */ Wrong: This sentence should present a sufficient requirement and not only a maybe necessary requirement (like large than 0) Correct would have been: "larger than the sum of the sizes returned from MPI_PACK_SIZE for 1 MPI_INT and 200 MPI_FLOAT"
Thanks for bringing this up, I added this to the agenda for today
2a. The procedural problem is that the presentation of changed files may be swammed by minor corrections like typos, grammer, formatting, removed hyphens, index entries, corrections of macro usage, ... The real text changes may be overseen. 3. Especially for the point-to-point chapter this is really hard. May be also for other chapter as seen in item 2. above. How to proceed with this problem? (Of course without loosing time on irrelevant changes.)
Not sure there is a good way - perhaps we should adjust how we handle this in the future by recommending to bundle only "like" changes in a single PR (only index, only grammar, ...), but for now this is too late. I think we have to rely on everyone looking through the PR and I would also like to see CC chairs to go over their chapter again, especially if we push the FRM by one meeting.
4. It is overseen, if reviews for RC 1 are partially overseen (or just not implemented). https://github.com/mpi-forum/mpi-issues/issues/341 is full of change requests. Only partially these requests have check boxes, partally not. And only partially, these check boxes are checked. The issue #341 was quietly moved on Jan 19 from 4.0 to 4.1. Are there other chapter with outstanding corrections? Can we fix it without no-no-votes by reading the required changes during this meeting and having them as errata votes next meeting? How to proceed with this problem?
We did indeed move some items, which were not deemed ready nor critical, to MPI 4.1 (typically as part of one of the virtual meetings, not sure anymore when this happened for this ticket). If you think this was done in error and the changes are critical (as they affect correctness), we should discuss this.
5. Did we oversaw other PRs (like the very old number PR425 merged very late)?
I have that PR on the list as part of the I/O chapter discussion today. Is there something else missing?
Best regards Rolf ----- Original Message ----- > From: "Main MPI Forum mailing list" <[email protected]> > To: "Main MPI Forum mailing list" <[email protected]> > Cc: "Wesley Bland" <[email protected]> > Sent: Thursday, February 18, 2021 8:58:55 PM > Subject: [Mpi-forum] Feb 2021 MPI Forum Meeting Plan > Hi all, > > I wanted to give an update on the plan for the meeting next week after our > virtual meeting yesterday. > > The original plan for the Feb 2021 meeting was to be a Final Ratification > Meeting (FRM), which would mean that at some point during the meeting, we would > potentially ratify MPI 4.0 and elect officers for the next release of the MPI > Standard. The rules for that are in our procedures document on our website and > it turns out they handle our current situation very well. The relevant pieces > are this: > > > > 1. At the last meeting, we made two lists of items that were not yet fixed. > These lists are maintained on agenda and voting page for the meeting: [ > https://www.mpi-forum.org/meetings/2021/02/votes | > https://www.mpi-forum.org/meetings/2021/02/votes ] > 2. > 1. The items that we knew about by the end of the December 2020 meeting - > Everything on this list that was fixed will be voted on using the same rules as > an errata vote . > 2. The items that were discovered after the end of the December 2020 meeting - > Everything on this list that was fixed will be voted on using the same rules as > a no-no vote . > 3. We will construct another list during the February 2021 meeting to keep track > of remaining issues that we see with the document. This list is in the same > place as where we tracked the previous work: [ > https://github.com/mpi-forum/mpi-issues/projects/2 | > https://github.com/mpi-forum/mpi-issues/projects/2 ] > 4. On a separate day from the items in #1 above, we will have a ballot to decide > whether the remaining issues should cause us to delay ratifying MPI 4.0. > 5. > 1. Without attempting to editorialize too much (people may vote in whatever way > they think is most appropriate), based on the conversations in the virtual > meeting yesterday, I would expect this ballot to pass. The ramifications of > that are below. > 6. If the ballot in #3 fails (saying the list of remaining items is not blocking > MPI 4.0), then we hold another ballot to ratify MPI 4.0. > 7. If the ballot in #3 passes (saying the list should block MPI 4.0), then the > February 2021 meeting essentially becomes a Release Candidate Meeting (RCM) > like our December 2020 meeting. This means: > 8. > 1. The June 2021 meeting becomes the new FRM meeting for MPI 4.0 > 2. The remaining items list becomes the “errata” list for the June meeting and > everything remaining on it should be addressed ASAP to allow time to discuss, > merge, and generate a new release candidate document for that meeting > (tentative deadline for PRs to be created would be April 19th, but they should > be created and hopefully merged long before that to avoid similar problems for > the next meeting). > 3. Any new items that are discovered before the next meeting can still be added > to the second list for a no-no vote. > 4. A new chapter-by-chapter reading is not necessary or required. > 5. Officer nominations will reopen and we will hold elections at the June > meeting. > > If we do decide to delay MPI 4.0, I don’t think the intention is to “open the > floodgates” for every small thing we’ve noticed is wrong in the document. As > Bill has said, we’ll never fix every little thing, so right now let’s focus on > the major issues that would cause problems and keep doing the rest for MPI 4.1. > If there are remaining issues from the previous lists that we’d like to > address, go ahead and create the PR for them and we can make a decision later > on whether to vote it into MPI 4.0 or 4.1. Either way, the PR will be useful. > > In order to get through all of the things above and still have time to discuss > the remaining technical issues, we’re going to have to be very aggressive in > our timeline for reading all of the changes since the last meeting. As you can > see on the votes page, we have 76 issues to be read. In an effort to get those > done as quickly as possible, Martin and I will be going through the issues/PRs > and asking for input from others as we go (but avoiding context switching from > laptop to laptop between each issue). We hope this will give us time to finish > the entire set of issues on day one or two. > > If there are items that begin to have prolonged technical discussion, we will > take that as a sign that the issue needs more discussion with the relevant > groups outside of the full-forum meeting time, which is very limited. The > interested parties should schedule a separate time to have those discussions > and bring the results back in a future virtual meeting over the next month or > two. > > If you haven’t registered for the meeting for next week, please do so now on the > logistics page: [ https://www.mpi-forum.org/meetings/2021/02/logistics | > https://www.mpi-forum.org/meetings/2021/02/logistics ] I’ll be updating the > attendance page periodically, but keep in mind that the process is manual so it > doesn’t happen immediately. > > That’s all from me for now. I think Martin had some more thoughts about what to > do with the remaining technical items that he’ll address in another email. > > Thanks, > Wes > > _______________________________________________ > mpi-forum mailing list > [email protected] > https://lists.mpi-forum.org/mailman/listinfo/mpi-forum -- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
Martin Schulz
