Re: [Mpi-forum] Giving up on C11 _Generic
Hi JeffH, After a brief search that I never knew was necessary, I find that “all” is smaller than “everything” in clang world. http://clang.llvm.org/docs/UsersManual.html#enabling-all-diagnostics So, my question “why isn’t -Wconversion implied by -Wall?” might have an astonishing answer. The resulting workflow is then: 1) notice the symptoms of a bug in the output/effect of the code 2) re-compile with -Weverything -Wno-c++98-compat -Wno-c++-compat 3) re-compile with -Weverything -Wno-c++98-compat -Wno-c++-compat -Wno-<other-conflicts> 4) re-compile with -Weverything -Wno-c++98-compat -Wno-c++-compat -Wno-<other-conflicts> -Wno-<unrelated> 5) address all remaining warnings by changing code Experience and repeated exposure would permit combining steps 2-4. This is documented, once you know to go look for it. However, it was not obvious to me that looking beyond “-Wall” was needed. Whilst I agree wholeheartedly that “incorrect programs are incorrect”, I think designers of interfaces/standards have some responsibility to select a design that makes it easy to discover incorrect usage over one that makes it hard. Ideally, a design should be selected that makes it hard to form incorrect usage rather than one that makes misuse easy. Cheers, Dan. — Dr Daniel Holmes PhD Architect (HPC Research) [email protected]<mailto:[email protected]> Phone: +44 (0) 131 651 3465 Mobile: +44 (0) 7940 524 088 Address: Room 2.09, Bayes Centre, 47 Potterrow, Central Area, Edinburgh, EH8 9BT — The University of Edinburgh is a charitable body, registered in Scotland, with registration number SC005336. — On 7 Aug 2019, at 21:14, Jeff Hammond via mpi-forum <[email protected]<mailto:[email protected]>> wrote: I don't care that much about C11 _Generic, which is why I have always focused on a C99 solution to the large-count problem, but I disagree with your reasons for abandoning it. "silently truncated at run time" is trivially addressed with -Wconversion or -Wshorten-64-to-32. The example program below is addressed by this. $ clang -Wshorten-64-to-32 -c truncation.c truncation.c:10:9: warning: implicit conversion loses integer precision: 'long long' to 'int' [-Wshorten-64-to-32] foo(i); ~~~ ^ 1 warning generated. $ gcc-9 -Wconversion -c truncation.c truncation.c: In function 'main': truncation.c:10:9: warning: conversion from 'long long int' to 'int' may change value [-Wconversion] 10 | foo(i); | ^ $ icc -Wconversion -c truncation.c truncation.c(10): warning #1682: implicit conversion of a 64-bit integral type to a smaller integral type (potential portability problem) foo(i); ^ In any case, incorrect programs are incorrect. It is a quality-of-implementation issue whether C compilers and MPI libraries detect incorrect usage. We have never designed MPI around people who can't follow directions and we should not start now. Jeff On Wed, Aug 7, 2019 at 6:59 AM Jeff Squyres (jsquyres) via mpi-forum <[email protected]<mailto:[email protected]>> wrote: SHORT VERSION ============= Due to the possibility of silently introducing errors into user applications, the BigCount WG no longer thinks that C11 _Generic is a good idea. We are therefore dropping that from our proposal. The new proposal will therefore essentially just be the addition of a bunch of MPI_Count-enabled "_x" functions in C, combined with the addition of a bunch of polymorphic MPI_Count-enabled interfaces in Fortran. MORE DETAIL =========== Joseph Schuchart raised a very important point in a recent mailing thread: the following C/C++ code does not raise a compiler warning: ----- #include <stdio.h> static void foo(int j) { printf("foo(j) = %d\n", j); } int main(int argc, char *argv[]) { /* 8589934592LL == 2^33 */ long long i = 8589934592LL + 11; foo(i); return 0; } ----- If you compile and run this program on a commodity x86-64 platform, a) you won't get a warning from the compiler, and b) you'll see "11" printed out. I tried with gcc 9 and clang 8 -- both with the C and C++ compilers. I even tried with "-Wall -pedantic". No warnings. This is because casting from a larger int type to a smaller int type is perfectly valid C/C++. Because of this, there is a possibility that we could be silently introducing errors into user applications. Consider: 1. An application upgrades its "count" parameters to type MPI_Count for all calls to MPI_Send. --> Recall that "MPI_Count" already exists in MPI-3.1, and is likely of type (long long) on commodity x86-64 platforms 2. The application then uses values in that "count" parameter that are greater than 2^32. If the user's MPI implementation and compiler both support C11 _Generic, everything is great. But if either the MPI implementation or the compiler do not support C11 _Generic, ***the "count" value will be silently truncated at run time***. This seems like a very bad idea, from a design standpoint. We have therefore come full circle: we are back to adding a bunch of "_x" functions for C, and there will be no polymorphism (in C). Sorry, folks. Note that Fortran does not have similar problems: 1. Fortran compilers have supported polymorphism for 20+ years 2. Fortran does not automatically cast between INTEGER values of different sizes After much debate, the BigCount WG has decided that C11 _Generic just isn't worth it. That's no reason to penalize Fortran, though. -- Jeff Squyres [email protected]<mailto:[email protected]> _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpi-forum -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
HOLMES Daniel
