Re: [Mpi-forum] "BigCount" rendering in PDF
That’s why there will be C90/C99 compatible symbols as well. If you don’t like C11, don’t use it. Nothing will happen. BigCount will still work. C11 has been the default in GCC and Clang for a while. What compilers are going to limit users to C99 for years to come? Jeff
On Aug 1, 2019, at 3:23 AM, N.M. Maclaren via mpi-forum <[email protected]> wrote:
On Jul 30 2019, Jeff Squyres (jsquyres) via mpi-forum wrote:
B. C11 _Generic polymorphism kinda sucks, *and* we're in a transition period where not all C compilers are C11-capable. Hence, we're exposing up to *3* C bindings per MPI procedure to applications (including explicitly exposing the "_x" variant where relevant).
This following point may have already been debated, so please excuse me if has. Let's skip the politics, for the sake of all our blood pressures.
The executive summary is that the failure mode pointed out by Joseph Schuchart is going to be a very, very serious problem for BigCount users, and continue for the forseeable future. I would guess until at least 2025, and possibly long after that.
Speaking as someone who may be teaching MPI programming again, with an emphasis on reliability and portability, I would almost certainly add warnings that would be, roughly: "Don't touch BigCount if you can find a way round it; and be paranoid about it if you use it." I already do that about I/O attributes, for similar reasons. That isn't good.
I don't know how you would document that, but the MPI standard already has gotchas that aren't easy to find, and adding another one isn't good, either.
The explanation:
C99 was not received favourably by most of the C-using community (I don't mean compilers here). I tracked a dozen important, active projects, and it was 2010/11 (yes, over a decade) before even half of them converted from C90 to C99 as a base. I last checked a few years ago, but quite a few C99 features were still not reliably available in compilers; I know that many of the ones I found still aren't. Courses are another problem, because they rarely include warnings about gotchas caused by standards differences (and there are lots between C90 and C99).
I haven't tracked C11 as carefully, but the evidence I have seen is that it received even less interest and acceptance than C99, so people are going to be using C99 compilers for a LONG time yet. There is also the problem that C is not a language that is upwards compatible between versions, but C++ takes more notice, so C++ compilers' C support (which is arguably more important than direct C support, because people call MPI using C++'s C interface) is often in conflict. This is almost certainly a case where that will be true, but it may not affect these interfaces - I can't say.
The result is that C code (and, worse, libraries) often require specific versions (i.e. not just 'any standard later than'). I agree that it looks likely that generic interfaces are going to be one of the more widely implemented parts of C99, but don't discount the problem of people using multiple libraries where other ones constrain the C version for other reasons.
_______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
Jeff Hammond
