Re: [Mpi-forum] MPI-IO for mesh based simulations beyond 2 billion elements
Doug and all other implementors, is there any platform and MPI library at IBM and elsewhere that has an MPI_Aint and INTEGER(KIND=MPI_ADDRESS_KIND) less than 64 bit? Harald, further details below. Best regards Rolf ----- Original Message -----
From: "Harald Klimach" <[email protected]> To: "Rolf Rabenseifner" <[email protected]> Cc: "Main MPI Forum mailing list" <[email protected]> Sent: Sunday, February 19, 2012 11:55:35 AM Subject: Re: MPI-IO for mesh based simulations beyond 2 billion elements Dear Rolf,
thanks a lot for your quick response and guidance. MPI_Type_create_resized defines LB and Extent as MPI_ADDRESS_KIND. What is this going to be on 32-Bit systems like the BlueGene? As far as I understand it, my chances for larger numbers are better with MPI_OFFSET_KIND? Thus, to me it looks like it is not possible to use the MPI Type facilities for large data sets in order to describe the IO layout for one-dimensional data. Instead I have to use the disp parameter in MPI_File_set_view. Is there any disadvantage attached to this, especially when doing collective IO? Could MPI-Implementations exploit the data provided in the types better than individual disp in the view?
With the resized datatype, the MPI library can detect that all filetypes collectively provided in MPI_SET_FILE_VIEW are disjunct! This may allow optimizations that are not possible with defining different disp in MPI_SET_FILE_VIEW; here, the first process will see the whole file, the all other ranks the whole file minus the portion really accessed by the processes with smaller ranks. Rolf
Thanks, Harald
Am 19.02.2012 um 11:23 schrieb Rolf Rabenseifner:
Dear Harald, dear I/O and datatype committee members,
Indeed, you need a workaround. Our LARGE COUNT #265 is not enough. The workaround (instead of MPI_TYPE_CREATE_SUBARRAY) is:
1. Call MPI_FILE_SET_VIEW(fh, 0, vectype, vectype, datarep, MPI_INFO_NULL, iError) 2. Call MPI_FILE_GET_TYPE_EXTENT(fh, vectype, vectype_byte_extent, iError) 3. Byte_elemOffset = elemOff (as in your source code) * vectype_byte_extent Byte_GlobalSize = globElems (as in your source code) * vectype_byte_extent 4. Call MPI_Type_contiguous(locElems, vectype, chunktype, iError) 5. Call MPI_TYPE_CREATE_RESIZED(chunktype,-Byte_elemOffset, Byte_GlobalSize, ftype) (I hope that I understood thisroutine correctly and here, a negativ lb is needed.)
6. call MPI_File_set_view( fh, 0_MPI_OFFSET_KIND, &
& vectype, ftype, "native", & & MPI_INFO_NULL, iError )
Any comments by specialists?
Best regards Rolf
From: "Harald Klimach" <[email protected]> To: "Rolf Rabenseifner" <[email protected]> Sent: Sunday, February 19, 2012 10:05:40 AM Subject: MPI-IO for mesh based simulations beyond 2 billion elements
Dear Rolf,
Mesh based simulations are an important backbone of CFD. The mesh sizes we are capable to compute on new HPC systems steadily increases even for complex geometrical layouts. For simple geometries, much larger domains then 2 billion elements where already done 10 years ago, see M. Yokokawa, K. Itakura, A. Uno, T. Ishihara and Y. Kaneda, "16.4-TFlops Direct Numerical Simulation of Turbulence by a Fourier Spectral Method on the Earth Simulator", Proceedings of the 2002 ACM/IEEE Conference on Supercomputing, Baltimore MD (2002). To describe the spatial domain around complex geometries usually some unstructured approach has to be followed to allow a sparse representation. This results in a one-dimensional list of all elements which is distributed across all processes in a parallel simulation. Therefore the natural representation of all elements in each partition is perfectly described by an one-dimensional MPI subarray datatype. This would also be the most natural choice to describe the MPI File view for each partition to enable dumping and reading of results and restart data. However, due to the interface definition of MPI_Type_create_subarray, the global problem size would be limited to roughly 2 billion elements by MPI.
Here is the actual implementation we are facing in our Code: We use a Lattice-Boltzmann representation, where each element is described by 19 MPI_DOUBLE_PRECISION values:
call MPI_Type_contiguous(19, MPI_DOUBLE_PRECISION, vectype, iError) call MPI_Type_commit( vectype, iError )
This type is then used to build up the subarray description of each partition:
call MPI_Type_create_subarray( 1, [ globElems ], [ locElems ], [ elemOff ], & & MPI_ORDER_FORTRAN, vectype, ftype, iError) call MPI_Type_commit( ftype, iError )
Where globElems is the global number of Elements, locElems the number of Elements in the process local partition, and elemOff the Offset of the process local partition in terms of elements. This type is then used to set the view for the local process on a file opened for MPI-IO:
call MPI_File_open( MPI_COMM_WORLD, & & 'restart.dat', & & MPI_MODE_WRONLY+MPI_MODE_CREATE, & & MPI_INFO_NULL, fhandle, & & iError )
call MPI_File_set_view( fhandle, 0_MPI_OFFSET_KIND, & & vectype, ftype, "native", & & MPI_INFO_NULL, iError )
Finally the data is written to disk with collective write:
call MPI_File_write_all(fhandle, data, locElems, vectype, iostatus, iError)
The global mesh is sorted according to a space-filling curve and to provide mostly equal distribution on all processes, the local number of elements is computed by the following integer arithmetic:
locElems = globElems / nProcs if (myrank < mod(globElems, nProcs) locElems = locElems + 1
Where nProcs is the number of processes in the communicator and myRank the rank of the local partition in the communicator. Note, that for differently sized elements, the workload varies and the elements shouldn't be distributed equally for work load balance. And with different partitioning strategies other distributions might arise. However in any case it is not generally possible to find common discriminators greater than one across all partitions. Thus it is not easily possible to find a larger etype, which spans more than a single element.
What is the recommended implementation for efficient parallel IO within MPI in such a scenario?
Thanks a lot, Harald
-- Dipl.-Ing. Harald Klimach
German Research School for Simulation Sciences GmbH Schinkelstr. 2a 52062 Aachen | Germany
Tel +49 241 / 80-99758 Fax +49 241 / 806-99758 Web www.grs-sim.de JID: [email protected]
Members: Forschungszentrum Jülich GmbH | RWTH Aachen University Registered in the commercial register of the local court of Düren (Amtsgericht Düren) under registration number HRB 5268 Registered office: Jülich Executive board: Prof. Marek Behr Ph.D. | Dr. Norbert Drewes
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
