Re: [Mpi-forum] cancel in standard
But the user did care about it, and they decided to cancel it. It may not be one message, but one per iteration. And the semantics is clear (even if the standard’s language isn’t). Bill On Jun 3, 2015, at 10:08 PM, Jeff Hammond <[email protected]> wrote:
What's the harm in letting a message that the user clearly does not care about sit in a queue/buffer forever? I consider this an acceptable consequence of a really stupid feature.
Jeff
On Wed, Jun 3, 2015 at 9:50 PM, William Gropp <[email protected]> wrote:
Pavan is correct about the intent, and we could make this more precise. The basic requirement is that a message is *guaranteed* to either be canceled (on send) or received. Sitting in a queue or buffer somewhere does not count.
Bill
On Jun 3, 2015, at 7:19 PM, Balaji, Pavan <[email protected]> wrote:
[Cc'ed the Forum]
This wording has been debated many times at the Forum. Specifically, the "completes normally" and "received at the destination" pieces are ambiguous. For instance, if the data is copied into a bounce buffer, the send would complete normally, but that does not mean that there is a receive posted for that data. In this case, it would be the user's responsibility to post a corresponding receive. If the MPI implementation does not have a bounce buffer (e.g., for large messages), "received at the destination" could mean into an unexpected buffer, not necessarily a user buffer.
The consensus from MPI-1 veterans (Marc, Bill, etc.) during the last discussion was that if the application does not post a receive, then it is guaranteed that the send should be cancelable. At least that was the intent. The wording, of course, is too vague for such a definition.
You could try to weaken that interpretation and say that if the MPI implementation is not able to cancel a send operation, then the user is responsible for posting a matching receive to receive that data. Irrespective of which interpretation we go with, I think it is important to clarify it in the standard. Perhaps an MPI-3.1 errata or MPI-3.2 change instead of waiting for MPI-4? Do you want to create a ticket?
-- Pavan
On 6/3/15, 7:05 PM, "Sur, Sayantan" <[email protected]> wrote:
What lines in the standard support the interpretation that “a message that will not be successfully matched, must be cancelable”?
This is what I found, and it doesn’t support the stricter interpretation.
"If a send is marked for cancellation, then it must be the case that either the send completes normally, in which case the message sent was received at the destination process, or that the send is successfully cancelled, in which case no part of the message was received at the destination. Then, any matching receive has to be satisfied by another send."
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
William Gropp
