Re: [Mpi-forum] Compile problems with examples in MPI Standard
Thanks. Clearly, we need to change the prototype for MPI_Init and MPI_Init_thread. The best choice is probably back to the original: char ***argv_p since that's what it is (complete with a rationale for why it isn't what we're currently using). I prefer this to the char (*(*(argv_p[]))), since the usual inside-out reading of that is "argv_p is an array of pointers to pointers", which isn't the intent, though it might make the compiler happy. Bill William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign On Jul 24, 2012, at 10:42 AM, N.M. Maclaren wrote:
On Jul 24 2012, William Gropp wrote:
Here's the test case for everyone. No const.
int MPI_Init( int *argc_p, char *((*argv_p)[]) ); int main( int argc, char *argv[] ) { MPI_Init( &argc, &argv ); return 0; }
Ah. Yes, that's erroneous. The type of &argv is 'char ***', though both of the following should work:
int MPI_Init( int *argc_p, char ***argv_p ); int MPI_Init( int *argc_p, char **argv_p[] );
You can add parentheses ad lib, provided that you bind the array brackets to the name, as in:
int MPI_Init( int *argc_p, char (*(*(argv_p[]))) );
Regards, Nick Maclaren.
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
William Gropp
