Re: [Mpi-forum] make check is busted!
Hmm. I'm not sure how that happened since I use emacs on a Mac... I'll look into it. On Tue, 31 Jan 2012, William Gropp wrote:
The problem in prof.tex may be that this is a DOS formatted file - the standard has been to use Unix-style text files (newline line terminators, not return/newline).
The correct fix is to restore this to a Unix-style text file (as it was in MPI 2.2)
Bill
On Jan 31, 2012, at 4:01 PM, Fab Tillier wrote:
I think the errors in the profiling chapters are benign:
Checking examples in ./chap-prof Opening file prof.tex ex256.c: In function 'PMPI_Example': ex256.c:11: warning: control reaches end of non-void function Error or warning detected in example on line 296 (prof.tex): ex296.c:7: error: 'FUNCTION' declared as function returning a function
This has to do with the FUNCTION() macro used in the example, being treated as a function itself. I don't have the slightest clue how to 'fix' this.
Example contains ... at line 325 Error or warning detected in example on line 321 (prof.tex): ex321.c:6: error: expected identifier or '(' before '%' token
This one is probably a parsing issue, as it is not really code, but an example command line...
-Fab
Bronis R. de Supinski wrote on Tue, 31 Jan 2012 at 11:51:03
Hmm. That could explain why Fab found issues with the profiling chapter. I checked it in the past and I have not modified the examples so they should still work...
On Tue, 31 Jan 2012, Jeff Squyres wrote:
Ok.
I should also note that some of the warnings that come up when you "make check" are dependent on your MPI implementation. E.g., in the F90 examples, if your "use mpi" module doesn't explicitly declare MPI functions, you may get warnings that they aren't declared. But that's not a problem in the example code; it's a limitation of your MPI implementation.
On Jan 31, 2012, at 10:51 AM, William Gropp wrote:
These should be managed by the chapter committees, and voted on a part of the chapter. It would be counterproductive to vote on these individually.
Operationally, it is very difficult to mark up the text within the verbatim environment - frankly, the effort to do so is not worthwhile.
My recommendation is to make the chapter committees responsible for these. Note that in some cases, the "fixes" are to the annotations, and do not change the text, and hence need no vote.
Bill
On Jan 31, 2012, at 9:28 AM, Jeff Squyres wrote:
Bill --
If we make minor changes in examples in the text, do we need to annotate them with "ticket 0" so that they can be ultimately voted on?
On Jan 31, 2012, at 10:16 AM, William Gropp wrote:
Fab,
Yes, make check should build cleanly. For example, the errors in coll.tex are Fortran 90 subroutines, listed as complete routines, that are missing the required "END" statement. There are also "naked" examples that don't have the proper annotations; these should be added.
For those that don't know about the "make check" option - this makes sure that our examples don't have simple errors in them - it requires a small amount of work to add the necessary annotations (documented and examples exist throughout the source) and our experience has been that this catches a lot of errors that would otherwise be missed. In looking over the make check output, I see quite a few of those. Chapter authors should check their chapters.
Bill
On Jan 30, 2012, at 4:07 PM, Fab Tillier wrote:
Hey Folks,
Is it reasonable for me to expect that building the examples in the standard wouldn't generate a bunch of errors? Do we build the examples before publishing drafts, etc?
Just running 'make check' on the approved/MPI-3.0 branch gives me a bunch of errors, in the following files: - chap-one-side/one-side-2.tex - chap-context/context.tex - chap-coll/coll.tex - chap-binding/binding-2.tex - chap-topol/topol.tex - chap-prof/prof.tex
Can the chapter owners figure out how to either fix or suppress these errors? It makes it really hard to find errors I may have introduced - the signal to noise ratio is really lousy. Alternatively, is there a 'correct' way of running 'make check' that won't generate these? I ran autoconf in mpicompilechk, then configure. Should I be specifying extra parameters or anything?
Thanks, -Fab
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
