Re: [Mpi-forum] Comment on Fortran WG5 ballot N1846
Bill, John, and all together, I want to explain the background of our comment from the MPI Forum, why we expect that ASYNCHRONOUS and VOLATILE are quite different und why we want to extent ASYNCHRONOUS to MPI nonblocking accesses ***without*** giving ASYNCHRONOUS a semantics similar to VOLATILE. For this, I have a few questions, i.e., I would like to see whether the background of our comment is correct, or not: 1. About the ASYNCHRONOUS attribute: I expect that the Fortran 2008 standard defines the outcome only if a user program is correct. If a program uses asynchronous Fortran I/O on a data structure buf (maybe an array or a derived type), and makes load and stores on buf (as part of numerical operations) in a program unit where buf is declared as ASYNCHRONOUS, then the outcome of the program is only defined, if the application is free of race-conditions. Freeness of race-conditions requires that store accesses are done only on that part of buf that are not part of asynchronous Fortran I/O. Load accesses can be done only on that part of buf that is not part of the asynchronous Fortran input. Is this correct? 2. A compiler can do optimizations based on the assumption that this freeness of race-conditions is given. If the application violates the requirement of freeness of race-conditions, then the optimizations are still okay because then, the outcome of the program is anyway undefined. Is this correct? 3. My third question is about such allowed optimizations: Let buf_read be the part of buf that is used for asynchronous Fortran input, and buf_write by output, and buf_no_IO is not used in such I/O. The compiler can assume that loads are in buf_no_IO and buf_write, and all stores only in buf_no_IO. All optimizations are allowed that modify the sequence of accesses as long as the numerical outcome is still correct. All intermediate caching in registers, local memories or memory caches and reuse of the data form this caches is allowed to minimize memory loads, e.g., blocked execution of loop nests to achieve an optimal cache reuse. If the same location is written more than once, only the last value must be written to the memory. All such optimizations are not in any conflict with the ongoing asynchronous I/O on buf because these optimizations touch only buf_no_IO (with loads and stores) and buf_write (only with loads). Is this correct? 4. One type of optimization seems to be invalid: The optimization must not use elements of buf that are not used in the numerical execution, because these parts may be part of buf_read or buf_write. I.e., if some elements of buf should be temporarily overwritten for a loop fusion, then copying the value of such an element into a scratch buffer, then executing the fused loop, and then restoring the element based on the scratch value, such an optimization is forbidden when buf is declared with the ASYNCHRONOUS attribute. Is this correct? (This is the example in our comment to your ballot, that we want to exclude through the use of the ASYNCHRONOUS attribute.) 5. If buf is without an ASYNCHRONOUS (or VOLATILE) attribute, then the optimization in 4. would be valid as long as there are no other constraints. Correct? 6. Now about VOLATILE, i.e., we declare buf as VOLATILE: All accesses to buf must be done directly from main memory. Usage of the registers or local memories inside of the CPU or GPU for caching data and reusing it for several accesses is forbidden. Is this correct? 7. With VOLATILE, it is also not allowed to modify the sequence of accesses, because "most recent" in Fortran 2008, 5.3.19 VOLATILE attribute, Note 5.25, implies also that the sequence of the execution must not be modified. Is this correct? 8. The statements in 6. and 7. together mean that all the optimizations showed in 3. are forbidden. For me, these are the major differences between VOLATILE and ASYNCHROUNOUS. Is this correct? Do I miss something important? Now about our comment for ballot 1846 on TR29113 in version N1845: We need exactly the meaning of the ASYNCHRONOUS attribute extended for other meanings of asynchronous input/output as e.g., asynchronous I/O in C (aio), nonblocking communication, one-sided communication and non-blocking parallel I/O in MPI. We want to have this extension with the same possibilities (see 3.) and restrictions (see 4.) on numerical optimizations as if the asynchronous Fortran I/O is implemented asynchronously. This sentence defines our goal. I expect that our wording
1 An entity with the ASYNCHRONOUS attribute is a variable that may be subject to asynchronous input/output or other asynchronous access by means other than Fortran.
Asynchronous input/output can be any asynchronous access to the variable or parts of it, potentially within the scope of this standard by Fortran asynchronous I/O or possibly via methods outside the scope of this standard, such as the libc/POSIX asynchronous IO (aio) or nonblocking message passing, one-sided communication, or nonblocking parallel I/O as part of the Message Passing Interface (MPI) standard.
is not enough. It may be that an additional clarification is necessary to make clear that the application still has to be free of race-conditions. Last question: Which wording would you recommend to achieve our goal? Best regards Rolf ----- Original Message -----
From: "Richard L. Graham" <[email protected]> To: [email protected] Cc: "reinhold bader" <[email protected]>, "John Reid" <[email protected]>, "Main MPI Forum mailing list" <[email protected]>, "Craig Rasmussen" <[email protected]> Sent: Thursday, March 31, 2011 7:18:38 PM Subject: Re: [Mpi-forum] Comment on Fortran WG5 ballot N1846 Bill, The concern that was raised to me (I have not followed the standard, but rely on other folks in the forum for this) is that there is potential for incorrect behavior if a single data object is being used both for computation and for asynchronous communication (disjoint portions of the object are involved in each). The specific concern, if I understood things correctly - others, please correct me if I am wrong - that compilers may respect the ASYNCHRONOUS only with respect to other fortran libraries, such as fortran async I/O, and feel free to modify portions of the buffer being used for communications, only later to restore the parameters. If this is indeed what could happen, this would clearly be a correctness problem for MPI. Seems to me that if this is indeed an issue, MPI will not be the only thing impacted, but also code using other languages, async libraries, etc. It is possible that there is a misunderstanding here, but with the concern about potential correctness issues, want to raise this earlier rather than later. Is there something to be concerned about here ?
Thanks, Rich
On 3/30/11 11:24 PM, "Bill Long" <[email protected]> wrote:
Hi Rich and others,
On 3/30/11 11:51 AM, Graham, Richard L. wrote:
Dear member of the WG5 and J3 Fortran standardization committee,
As I understand the core of this thread, the problem is that some vendors don't actually implement anything for ASYNCHRONOUS because their libraries do not support actual asynchronous I/O operations, which makes the ASYNCHRONOUS semantics moot. If all of the vendors supported the semantics as expected, there would be no need for any changes.
We recommend the following change of the first two paragraphs in this section of the Fortran 2008 standard:
5.3.4 ASYNCHRONOUS attribute
The "or other asynchronous access be means other than Fortran" seems semantically identical to "an object may be referenced, defined, or become undefined, by means not specified by the program.". The second phrase is, of course, the definition of the VOLATILE attribute. The proposed change, then, seems to have the effect of making ASYNCHRONOUS the same as VOLATILE. Some comments on that possibility:
1) It is probably true that some vendors implement ASYNCHRONOUS that way already.
2) The vendors that are more precise in their ASYNCHRONOUS implementation would not be in favor of this change.
3) If this is the only solution, then using VOLATILE directly, and forgetting about ASYNCHRONOUS, would be a solution for the MPI non-blocking transfer routines. The implementation of VOLATILE is likely more uniform and widespread.
This should be treated only as a wording proposal. We provide the above text only as a suggestion; J3/WG5 are certainly free to adjust it as they feel necessary. The key idea is that we need ASYNCHRONOUS to also include potential memory modifications from agents outside the scope of the Fortran standard.
Right. Sounds like VOLATILE to me.
The following snipit is a correct code that allows the MPI library to internally use DMA, communications offload (e.g., to a NIC), or other method to asynchronously communicate parts of the array while the user application/main CPU simultaneously reads and writes to ***another*** part of the same array. Specifically, this code snipit is is free of race conditions.
USE mpi_f08 REAL, ASYNCHRONOUS :: buf(100,100) ! communicating a boundary of the array: CALL MPI_Irecv(buf(1,1:100),...req,...) DO j=1,100 DO i=2,100 buf(i,j)=.... ! work only on the inner area END DO END DO CALL MPI_Wait(req,...)
It is not clear to me how this program example would show any difference in performance or semantics if ASYNCHRONOUS were replaced by VOLATILE. Even with the current definitions of the attributes, it is extremely unlikely that a compiler applies the asynchronous attribute on an element by element basis for the array buf.
With the current status of Fortran 2008 + TR 29113 (Version N1845), a compiler can ignore the ASYNCHRONOUS attribute. For example, a compiler may choose to not implement Fortran asynchronous I/O in an asynchronous way, meaning that there is no need for the compiler to make any restrictions on optimization.
To be clear: with the current Fortran 2008, this optimization is still allowed. With our proposal, this optimization will be prohibited.
We want to mention that the use of VOLATILE would solve the problem, but at a high performance price because it would also prohibit any optimization of the "work" part (e.g., automatic cache optimization, instruction reordering, etc.). Especially since Fortran is used with MPI in high-performance, numerically intensive applications, we feel that VOLATILE cannot be recommended as a solution.
So, it appears that you are saying that the compiler cannot make the element-by-element distinction for the VOLATILE attribute, but it could for ASYNCHRONOUS (in order for your example to optimize the way you hope). Seems like a weak point in the argument.
I agree that VOLATILE has the issues you state. But I don't see how the new definition of ASYNCHRONOUS avoids the same issues.
The MPI standard can state what is required of compiler implementations for them to be compatible with MPI. I think a more direct solution would be to require that the compiler vendor supports the ASYNCHRONOUS semantics if it is to be used with MPI.
Cheers, Bill
-- Bill Long [email protected] Fortran Technical Support & voice: 651-605-9024 Bioinformatics Software Development fax: 651-605-9142 Cray Inc./Cray Plaza, Suite 210/380 Jackson St./St. Paul, MN 55101
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
