Re: [Mpi-forum] make check is busted!
Yes, this relies on at least a valid mpi.h header file - for the new features, I'll need to create one for all of the MPI 3 additions. Bill On Jan 31, 2012, at 1:51 PM, Bronis R. de Supinski wrote:
Hmm. That could explain why Fab found issues with the profiling chapter. I checked it in the past and I have not modified the examples so they should still work...
On Tue, 31 Jan 2012, Jeff Squyres wrote:
Ok.
I should also note that some of the warnings that come up when you "make check" are dependent on your MPI implementation. E.g., in the F90 examples, if your "use mpi" module doesn't explicitly declare MPI functions, you may get warnings that they aren't declared. But that's not a problem in the example code; it's a limitation of your MPI implementation.
On Jan 31, 2012, at 10:51 AM, William Gropp wrote:
These should be managed by the chapter committees, and voted on a part of the chapter. It would be counterproductive to vote on these individually.
Operationally, it is very difficult to mark up the text within the verbatim environment - frankly, the effort to do so is not worthwhile.
My recommendation is to make the chapter committees responsible for these. Note that in some cases, the "fixes" are to the annotations, and do not change the text, and hence need no vote.
Bill
On Jan 31, 2012, at 9:28 AM, Jeff Squyres wrote:
Bill --
If we make minor changes in examples in the text, do we need to annotate them with "ticket 0" so that they can be ultimately voted on?
On Jan 31, 2012, at 10:16 AM, William Gropp wrote:
Fab,
Yes, make check should build cleanly. For example, the errors in coll.tex are Fortran 90 subroutines, listed as complete routines, that are missing the required "END" statement. There are also "naked" examples that don't have the proper annotations; these should be added.
For those that don't know about the "make check" option - this makes sure that our examples don't have simple errors in them - it requires a small amount of work to add the necessary annotations (documented and examples exist throughout the source) and our experience has been that this catches a lot of errors that would otherwise be missed. In looking over the make check output, I see quite a few of those. Chapter authors should check their chapters.
Bill
On Jan 30, 2012, at 4:07 PM, Fab Tillier wrote:
Hey Folks,
Is it reasonable for me to expect that building the examples in the standard wouldn't generate a bunch of errors? Do we build the examples before publishing drafts, etc?
Just running 'make check' on the approved/MPI-3.0 branch gives me a bunch of errors, in the following files: - chap-one-side/one-side-2.tex - chap-context/context.tex - chap-coll/coll.tex - chap-binding/binding-2.tex - chap-topol/topol.tex - chap-prof/prof.tex
Can the chapter owners figure out how to either fix or suppress these errors? It makes it really hard to find errors I may have introduced - the signal to noise ratio is really lousy. Alternatively, is there a 'correct' way of running 'make check' that won't generate these? I ran autoconf in mpicompilechk, then configure. Should I be specifying extra parameters or anything?
Thanks, -Fab
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
-- Jeff Squyres [email protected] For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/
participants (1)
William Gropp
