All MPI implementors: Implementation of MPI constants in C and Fortran / MPI meeting May 3, 2023 9am CDT discussion
Dear implementor of an MPI library, Based on the discussion today in the MPI forum meeting, I have the following urgent question to you: Did you implement all MPI constants that are described in Annex A.1.1 as of type "const int (or unnamed enum)" as "C integer constant expression" (according to the specification of the C language)? If yes, then all is okay and the proposed change of the MPI standard in https://github.com/mpi-forum/mpi-standard/pull/821/files will not require any change of your MPI implementation. If not, then please can you tell which MPI constant(s) MPI_XXX - have you implemented in a way that - it still can be used in an initialization expression, i.e., in a application statement like int x=MPI_XXX; - but it cannot be used as a case-label in a switch statement like switch(MPI_XXX) { case MPI_XXX: printf("XXX\n"); default: ; } - and cannot be used as a fixed array length in a declaration like float x[MPI_XXX]; - and how implemented you such an MPI constant that this problem arises? We'll discuss this again tomorrow May 3, 2023 at the beginning of the MPI forum meeting. See you hopefully at the meeting, and hopefully reporting that you have no problem with the proposal, kind regards Rolf ----- Original Message -----
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Puri Bangalore" <[email protected]>, "Claudia Blaas-Schenner" <[email protected]>, "Jeff Hammond" <[email protected]> Sent: Tuesday, May 2, 2023 2:04:01 PM Subject: Re: Informal meeting announcement for the May 2023 meeting of the MPI Forum
Der forum memebers, dear Wesley,
please can we add in the agenda after
Informal Errata Reading 705 Fortran has only compile-time constants Rolf
an additional slot
Errata Discussion 657 All C const int (or unnamed enum) as compile-time constants Rolf, Jeff H.
Bestr regards Rolf
From: "Rolf Rabenseifner" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Puri Bangalore" <[email protected]>, "Claudia Blaas-Schenner" <[email protected]> Sent: Saturday, April 29, 2023 7:38:00 AM Subject: Informal meeting announcement for the May 2023 meeting of the MPI Forum
Dear forum members,
I would like to make the following announcements for the next MPI Forum Meeting (May 2-5, 2023):
- informal reading and discussion #705 Errata: Fortran has only compile-time constants Rolf Issue https://github.com/mpi-forum/mpi-issues/issues/705 PR https://github.com/mpi-forum/mpi-standard/pull/819 PDF https://github.com/mpi-forum/mpi-standard/files/11358444/mpi41-report_Issue7...
This errata should be completely discussed in next (May 2-5, 2023) meeting. It is then planned to have an final errata reading plus errata vote at next meeting (July 10-13, 2023).
It is a bug since MPI-2.2 because a problem in C was directly mapped to Fortran. This mapping was wrong. In Fortran, there is no distinction between link-time and compile-time constants.
Best regards Rolf Rabenseifner
-- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany
participants (1)
Rolf Rabenseifner
