EuroMPI 2010: Call for Participation
[Apologies if you receive multiple copies of this message] *********************************************************************** CALL FOR PARTICIPATION (early bird deadline ends June, 30th 2010) *********************************************************************** 17th EuroMPI conference Stuttgart, Germany 12-15 September 2010 http://www.eurompi2010.org *********************************************************************** ABOUT THE CONFERENCE MPI (Message Passing Interface) has evolved into the standard interfaces for high-performance parallel programming in the message-passing paradigm. EuroMPI is the most prominent meeting dedicated to the latest developments of MPI, its use, including support tools, and implementation, and to applications using these interfaces. The 17th European MPI Users' Group Meeting will be a forum for users and developers of MPI and other message-passing programming environments. Through the presentation of contributed papers, poster presentations and invited talks, attendees will have the opportunity to share ideas and experiences to contribute to the improvement and furthering of message-passing and related parallel programming paradigms. Topics of interest for the meeting include, but are not limited to: - MPI implementation issues and improvements - Latest extensions to MPI - MPI for high-performance computing, clusters and grid environments - New message-passing and hybrid parallel programming paradigms - Interaction between message-passing software and hardware - Fault tolerance in message-passing programs - Performance evaluation of MPI applications - Tools and environments for MPI - Algorithms using the message-passing paradigm - Applications in science and engineering based on message-passing EuroMPI 2010 will hold the 'Outstanding Papers' sessions, where the best papers selected by the program committee will be presented. REGISTRATION Early bird registration ends June 30th, 2010. http://www.eurompi2010.org/registration/ INVITED SPEAKERS - Jack Dongarra (UTK and ORNL, USA) "The Challenges of Extreme Scale Computing" - Jan Westerholm (Abo Akademi University, Finland) "Observations on MPI usage in large scale simulation programs" - Rolf Hempel (Deutsches Zentrum für Luft- und Raumfahrt e.V., Germany) "Interactive Visualization of Large Simulation Datasets" - Jesus Labarta (Barcelona Supercomputing Center, Spain) "Detail at scale in performance analysis" - William Gropp (University of Illinois Urbana-Champaign, USA) "Does MPI Make Sense For Exascale Systems?" LIST OF ACCEPTED PAPERS (listed alphabetically) Mohamed Abouelhoda and Hisham Mohamed . Parallel Chaining Algorithms Rakhi Anand, Edgar Gabriel and Jaspal Subhlok . Communication Target Selection for Replicated MPI Processes Pavan Balaji, Darius Buntinas, David Goodell, William Gropp, Jayesh Krishna, Ewing Lusk and Rajeev Thakur . PMI: A Scalable Parallel Process Management Interface for Extreme-Scale Systems Aurelien Bouteiller, George Bosilca, Pierre Lemarinier, Thomas Herault and Jack Dongarra . Dodging the Cost of Unavoidable Memory Copies in Message Logging Protocols Ron Brightwell, Kurt Ferreira and Rolf Riesen . Transparent Redundant Computing with MPI Gabor Dozsa, Sameer Kumar, Pavan Balaji, Darius Buntinas, David Goodell, William Gropp, Joseph Ratterman and Rajeev Thakur . Enabling Concurrent Multithreaded MPI Communication on Multicore Petascale Systems Richard Graham, Ishai Rabinovitz, Pavel Shamis, Noam Bloch and Gilad Shainer . Network Offloaded Hierarchical Collectives Using ConnectX-2’s CORE-Direct Capabilities Timo Heister, Martin Kronbichler and Wolfgang Bangerth . Massively Parallel Finite Element Programming Scott Hemmert, Brian Barrett and Keith Underwood . Using Triggered Operations to Offload Collective Communication Operations Torsten Hoefler, Greg Bronevetsky, Brian Barrett, Bronis de Supinski and Andrew Lumsdaine . Efficient MPI Support for Advanced Hybrid Programming Models Torsten Hoefler and Steven Gottlieb . Parallel Zero-Copy Algorithms for Fast Fourier Transform and Conjugate Gradient using MPI Datatypes Torsten Hoefler, William Gropp, Rajeev Thakur and Jesper Larsson Traeff . Toward Performance Models of MPI Implementations for Understanding Application Scaling Issues Michael Hofmann and Gudula Ruenger . An In-place Algorithm for Irregular All-to-All Communication with Limited Memory Joshua Hursey, Chris January, Mark O'Connor, Paul Hargrove, David Lecomber, Jeffrey Squyres and Andrew Lumsdaine . Checkpoint/Restart-Enabled Parallel Debugging Vivek Kale and William Gropp . Load Balancing Regular Meshes on SMPs with MPI Rainer Keller and Richard L. Graham . Characteristics of the Unexpected Message Queue of MPI applications Seong Jo Kim, Yuanrui Zhang, Seung Woo Son, Ramya Prabhakar and Mahmut Kandemir . Automated Tracing of I/O Stack Dries Kimpe, David Goodell and Robert Ross . MPI Datatype Marshalling: A Case Study in Datatype Equivalence Jayesh Krishna, Pavan Balaji, Ewing Lusk, Rajeev Thakur and Fabian Tillier . Implementing MPI on Windows: Comparison with Common Approaches on Unix Jesper Larsson Träff . Compact and Efficient Implementation of the MPI Group Operations Jesper Larsson Träff . Transparent neutral element elimination in MPI reduction operations Teng Ma, George Bosilca, Aurelien Bouteiller and Jack Dongarra . Locality and Topology aware Intra-node Communication Among Multicore CPUs Stephanie Moreaud, Brice Goglin and Raymond Namyst . Adaptive MPI Multirail Tuning for Non-Uniform Input/Output Access Thorvald Natvig and Anne C. Elster . Run-Time Analysis and Instrumentation for Communication Overlap Potential Akihiro Nomura and Yutaka Ishikawa . Design of Kernel-level Asynchronous Collective Communication Paul Sack and William Gropp . A Scalable MPI_Comm_split Algorithm for Exascale Computing Michel Schanen, Uwe Naumann and Michael Förster . Second-Order Adjoint Algorithmic Differentiation by Source Transformation of MPI Code Jerome Soumagne, John Biddiscombe and Jerry Clarke . An HDF5 MPI virtual file driver for parallel in-situ post-processing Sarvani Vakkalanka, Anh Vo, Ganesh Gopalakrishnan and Robert Kirby . Precise Dynamic Analysis for Slack Elasticity: Adding Buffer Without Adding Bugs MORE INFORMATION Additional information about the conference can be found at: http://www.eurompi2010.org
participants (1)
Rolf Rabenseifner
