Re: [Mpi-forum] Process towards MPI 4.0 / Final Steps
This was removed from 4.0 because it was not considered an “emergency fix”. That’s not to say that it’s not worthwhile and we can’t or shouldn’t do it for 4.1, just that we’re going to remove all changes from the list that are not required so we can make sure to finish 4.0 in June. This can still be read in June and voted in to 4.1 in the usual time frame after that (1st in September, 2nd in December). Am I misunderstanding that there’s something breaking by not having this in 4.0? Thanks, Wes
On Mar 30, 2021, at 4:03 AM, Rolf Rabenseifner via mpi-forum <[email protected]> wrote:
Dear Martin, Wesley, Bill and all,
Please let us know if you have any questions or concerns - we will also address this in the meeting next week.
I detected that also Issue (K=) 468 was moved to MPI-4.1.
I updated the issues's abstract with a summary of the discussion (which was partially within the Parrived progress discussion) at the Feb. 2021 meeting.
Adding a 4th such test routine (after MPI_Test, Request_get_status, Win_test, Parrived), it gets significantly more evident if for only one routine, Request_get_status, there is no such written progress guarantee in the standard.
Therefore, we did this analysis and reading of adding at the Feb. meeting for voting it into the standard in June.
There is no reason to break this result from the Feb. 2021 meeting.
Therefore, I put https://github.com/mpi-forum/mpi-issues/issues/468 back to the triage.
@Martin please put it for tomorrow on the agenda.
Best regards Rolf
----- Original Message -----
From: "Main MPI Forum mailing list" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Cc: "Martin Schulz" <[email protected]> Sent: Wednesday, March 24, 2021 7:55:11 PM Subject: [Mpi-forum] Process towards MPI 4.0 / Final Steps
Hi all,
For those of you who had to miss the virtual MPI Forum meeting today, we had a discussion on the updated process towards MPI 4.0 and how to handle the final tickets.
The recording is at (with the right time-marker to this discussion): https://youtu.be/h9MO-BmbfdQ?t=2125
The slides are at: https://github.com/mpi-forum/mpi-forum.github.io/raw/master/slides/2021/03/2...
The quick summary is that we will limit the tickets that are still considered for MPI 4.0 to only emergency fixes that avoid breaking the standard and that are directly related to new items/procedures/concepts/text added specifically for MPI 4.0. Otherwise we fear (and we are seeing this already) that we may get clogged up with more and more changes that will not get the needed vetting and - equally important - that we run the risk of some issues not being accepted during the vote, which means the FRM is not the final document, which is problematic.
Wesley will be going through the board and classifying all issues based on that (see also slide 11) and then move tickets that do not meet the criteria to MPI 4.1 (changes that are already in, will stay , though). For this, we agreed to temporarily assume the role of a release manager that will advance tickets once they are ready (and that includes sufficient reviews by the CCs) and meet the criteria.
Note, though, this does not mean that the items tagged as 4.1 are postponed indefinitely - the plan is to start working on them right after MPI 4.0, if time permits, already in the June meeting. We should strive for getting a cleaned-up MPI 4.1 out the door soon, preferably before we add (m)any new items, but that part we will also discuss in the June meeting.
Thanks!
Martin (also in the name of Bill and Wesley)
-- Prof. Dr. Martin Schulz, Chair of Computer Architecture and Parallel Systems Department of Informatics, TU-Munich, Boltzmannstraße 3, D-85748 Garching Member of the Board of Directors at the Leibniz Supercomputing Centre (LRZ) Email: [email protected]
_______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] . High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 . University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 . Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) . _______________________________________________ mpi-forum mailing list [email protected] https://lists.mpi-forum.org/mailman/listinfo/mpi-forum
participants (1)
Wesley Bland
