Re: [Mpi-forum] MPI-3 implementations status
Rolf, The check marks are not meant to say that each feature is available on *all* platforms supported by the implementation. For all check marks, platform-specific restrictions apply. E.g., shared memory windows support is not available for many implementations on FreeBSD, but we don’t explicitly mark that either. I will put a generic caveat at the bottom of the slide. — Pavan
On Nov 13, 2014, at 2:33 AM, Rolf Rabenseifner <[email protected]> wrote:
Dear Pavan,
I'm not sure whether in some of the MPI libraries the "mpi_f08" module works only with a TS29113 Compiler and not with all Compilers that are supported by the "mpi" module.
Such a restrictions is not needed nor intended by MPI-3.0. MPI-3.0 has the same requirements for both, the "mpi" and the "mpi_f08" module.
If an MPI-3.0 implementation has such a restriction, it should be mentioned in the table.
Best regards Rolf
----- Original Message -----
From: "Pavan Balaji" <[email protected]> To: "Jonathan Perkins" <[email protected]> Cc: [email protected] Sent: Thursday, November 13, 2014 3:32:11 AM Subject: Re: [Mpi-forum] MPI-3 implementations status
Thanks, fixed.
On Nov 12, 2014, at 8:29 PM, Jonathan Perkins <[email protected]> wrote:
Hi Pavan. I just wanted to update about F08 Binding support with MVAPICH2. Recently we made a release (MVAPICH2 2.1a) based upon MPICH 3.1.2. With this I believe we can check the F08 Binding support box as well.
On Thu, Nov 13, 2014 at 01:26:40AM +0000, Balaji, Pavan wrote:
Folks,
With SC coming up, I want to make sure the attached slide on the MPI-3 implementations status is up to date.
Please take a look at your implementation’s status and let me know if any changes are to be made. Particularly, the cells that say “Q3 ’14” need to be changed to “Done” or replaced with some future date.
The updated slide will be presented at the various BoFs and other talks.
— Pavan
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jonathan Perkins
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . . . . (Office: Room 1.307) _______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
participants (1)
Balaji, Pavan
